Reply 33780 of 57718, by Deksor
jheronimus wrote on 2020-05-06, 00:30:
Deksor wrote on 2020-05-05, 23:43:
Oh among them is the most useless overdrive ever : the DX2 overdrive 😁
What would you say about an Overdrive SX-20 then? 😀
Well this one fits into a LIF 169 pin socket, which is useful when your motherboard has a soldered 486SX and a 487 upgrade socket. The DX2 overdrive on the other hand is exactly the same as a normal LIF168 DX2.
Reply 33781 of 57718, by Bancho
I had a nice system turn up today. I don't normally buy full systems, but this looked in great conditions and the parts looked to be really good also.
Its a Dan Mini Tower Intel 486 DX2 66mhz built in '94
Intel 486 DX2 66mhz
20mb ram (8x30pin Simm Modules)
Asus isa-486sv2 Rev 3.10 VLB motherboard (battery removed, no apparent damage)
Sound Blaster 16 CT-2830 SB16IDE (Genuine OPL3 onboard)
Promise VLB IDE Controller with 4mb cache
345MB Hard Disk
Cirrus Logic AcuMos ISA VGA Board
Serial/Parallel Card
Logitech Mouse Controller
Panasonic CD-Rom
Case is in lovely condition for its age. I've always liked these upside down towers. Bezel on the CD-ROM is yellowed so will try and sort that out.
I will upgrade the VGA Card to a Cirrus Logic VLB one i have and maybe fit a larger hard disk (1 or 2.1 gig)
Reply 33782 of 57718, by mpe
Deksor wrote on 2020-05-06, 11:34:
Depends if the DX2 overdrive is ODP or ODPR.
It isn't exactly the same. It doesn't have test scan signals, different cpu id. I also believe that UP# pin is always driven low on overdrive chips even on ODPR.
Also overdrive chips are always write-through. Ordinary DX2 chips have write-back cache in certain sspecs.
Blog|NexGen 586|S4
Reply 33783 of 57718, by MMaximus
PSU on the bottom... that was really ahead of its time 😀
Hard Disk Sounds
Reply 33784 of 57718, by liqmat
Bancho wrote on 2020-05-06, 12:53:
I had a nice system turn up today. I don't normally buy full systems, but this looked in great conditions and the parts looked t […]
Intel 486 DX2 66mhz
345MB Hard Disk
Panasonic CD-Rom
Very nice. Now you just need to put Microsoft Bob on Dan.
Reply 33785 of 57718, by imi
nice 😁
I'm still always looking out for those inverted AT cases, but they always get crazy expensive.
got a few sound cards :3
Terratec Maestro 16/95 Ver. 1.0 (16/96)
in box with tiny speakers and all goodies, partly still sealed, I think this one is actually new.
The attachment hardware38_42.jpg is no longer available
The attachment hardware38_43.jpg is no longer available
Terratec Base-1, I already had one of these, but got it for the wavetable board, Terratec WT64
The attachment hardware38_44.jpg is no longer available
míro Sound PCM1 Pro... after missing out on the one in a scrap lot I now got one with manuals :3
The attachment hardware38_45.jpg is no longer available
Guillemot Maxi Studio ISIS, seems complete
The attachment hardware38_46.jpg is no longer available
Reply 33786 of 57718, by austinham
imi wrote on 2020-05-06, 13:48:
nice :D I'm still always looking out for those inverted AT cases, but they always get crazy expensive. ... […]
nice 😁
just flip a case upside down?
Reply 33787 of 57718, by imi
that is not the same :p
the inverted cases have a very distinctive style, less tall, with the drive bays shifted to the side.
Reply 33788 of 57718, by pentiumspeed
Back in the day, one of local pc stores that I worked at and many stores around used those fat and short towers with those plastic rails, these were specially made so drives is not loose when installed.
Cheers,
Great Northern aka Canada.
Reply 33789 of 57718, by ShovelKnight
The attachment 34F5D09F-633F-4B30-8EB6-42EB17CF47F9.jpeg is no longer available
My Slot-1 rig is slowly getting there.
Reply 33790 of 57718, by ShovelKnight
https://i.imgur.com/dlDAEYTl.jpg https://i.imgur.com/4vtZo45l.jpg […]
This is my favourite Baby AT case style, I hope one day I will find one nearby without having to pay 100€ for shipping.
Reply 33791 of 57718, by appiah4
My P133 is in an inverted case. It is cool indeed 😀
Reply 33792 of 57718, by Cyrix200+
<snip>
Looks like it came from the same factory as this case, only a bit later 😀
1982 to 2001
Reply 33793 of 57718, by imi
^ that's the exact case I want ^^
Reply 33794 of 57718, by Intel486dx33
Cyrix200+ wrote on 2020-05-06, 14:57:
Looks like it came from the same factory as this case, only a bit later :) […]
<snip>
I had one of those back in 1990’s
I never used it however because I did not have the hard drive rails.
I regret sending it to the recyclers.
Nice case.
Reply 33795 of 57718, by APFSDS
I got a auzentech prelude and forte a couple of weeks and just got around to using them. The forte needs a heat sink because the rev.1 cards like to kill themselves.
uc?export=download&id=1ZsJC5uSru3IZlzauMkfrKxNLOVYrWsNP
Reply 33796 of 57718, by Cyrix200+
imi wrote on 2020-05-06, 15:00:
My dad's 386SX 16MHz came in this case. That's the machine I gamed on for a loooong time 😀
I was very happy when I finally found this case again. I have two now...
1982 to 2001
Reply 33798 of 57718, by imi
ShovelKnight wrote on 2020-05-05, 14:16:
It's not really retro but I bought a small mixer to plug all my PCs (modern and vintage) into it. Works a treat and helps to mitigate noise issues with old sound cards.
I was looking for a while too, stereo mixers are a rare breed, I've already got a behringer RX1602 but I finally found the one I was looking for at a local music store after multiple failed attempts on ebay, and its retro!
also some other stuff ...now I can get some more midi modules :3
The attachment studio01_01.jpg is no longer available
Reply 33799 of 57718, by boxpressed
Very cool. Do you know if this card can access the OPL4 for GM music from DOS?
