What NAS are you using ?
Reply 20 of 27, by chinny22
That's a great idea! Although can see myself running a few bench tests just to kick off a disco effect as well
Reply 21 of 27, by mrau
almost none use retro for this? i hoped to see a few sub ghz machines...
Reply 22 of 27, by Shagittarius
I just run a Synology DS214se. Does everything I need, use it for storing data and serving pictures and videos to my TV via Wifi. Running mirrored RAID also have backed up on a local drive in my main and an off-site data storage service.
Reply 23 of 27, by darry
mrau wrote on 2020-05-06, 18:19:
Performance (throughput) concerns relating to PCI bus bandwidth would be issues with that unless older server grade hardware with PCI-X was used . Either way, using old, now unreliable, small capacity disks from that era would not be very practical or safe . Using newer disks would require running SATA or SAS controllers in older hardware, or using IDE to SATA adapters and facing potential BIOS limitations . Also, when something fails, where do you get parts ?
EDIT : In other words, it's doable but why bother when cheap, reliable, high bandwidth, older (but not that old) commodity hardware is available for almost nothing and does a better job ? Then again, if somebody wants to use pre-2000 hardware for a NAS setup, good for him, but I personally think the inconveniences outweigh any coolness factor .
Reply 24 of 27, by wiretap
For the amount of storage required for modern file sizes, a retro computer would be slow, unreliable, loud, and draw far more power to keep running 24/7. A single 8TB NAS today can draw less than 25 watts from the wall. A 1GHz retro machine with 8TB would easily be over 250w for the amount of old SCSI drives needed.
Maybe have a separate topic for retro servers.
My Github
Circuit Board Repair Manuals
Reply 25 of 27, by darry
wiretap wrote on 2020-05-07, 00:21:
Even newer datacenter grade hardware will be loud and power hungry, but if you're going to endure that, might as well get the newer faster and more reliable hardware . If noise and power usage are any kind of a concern, either a consumer NAS running a lower power ARM CPU or a home-built relatively low power machine (an Athlon 200GE CPU like what I'm using draws 35W max at full load, much less otherwise) is a must .
EDIT: A topic for anybody still using retro hardware (15-20 years or older) in an actual server role might be fun indeed . I have a a Dell R710 (12 cores 192GB of RAM) that would be too to qualify anyway and gets used as a test environment anyway .
Reply 26 of 27, by Unknown_K
You can probably get away with just connecting a USB drive to your router (mine has a port for one).
Reply 27 of 27, by Srandista
No, but it's used for retro purposes as well. My NAS is set in a way, that all my Win9x and WinXP machines can access my NAS without issues. And it's super comfortable to get everything from network instead of USB/CD/floppy/whatever.
