First post, by brian105
- Member
Is it possible to see the compatible CPUs if I dump a BIOS? I believe that it's a Phoenix BIOS by Compaq, and while it's MVP3 I'm not too sure if it supports the K6+ CPUs since there's absolutely no documentation about these OEM boards. I wouldn't want to buy a K6+ and have to return it because it turns out that it's incompatible. The only issue is that currently, the latest BIOS is not flashed and in order to flash it, I need a floppy disk (which I don't have any for now) and I was wondering if I could flash it from the hard drive if I extract the BIOS update. However, I have no idea what the kind of files inside are, and they have weird file extensions.
From what I can tell, it's just a basic DOS boot floppy where there's a BIOS flashing utility, but also different BIOSes for different computers within the STRMxxxx files. I can't figure out how to open them, so maybe somebody's had experience with them. 686A1 is my ROM version as indicated within the readme and the BIOS chip onboard. I've attached the extracted BIOS files as well, and the update file itself.
Presario 5284: K6-2+ 550 ACZ @ 600 2v, 256MB PC133, GeForce4 MX 440SE 64MB, MVP3, Maxtor SATA/150 PCI card, 16GB Sandisk U100 SATA SSD
2007 Desktop: Athlon 64 X2 6000+, Asus M2v-MX SE, Foxconn 7950GT 512mb, 4GB DDR2 800, Audigy 2 ZS, WinME/XP
