VIDEO - 3dfx voodoo emulation (SDL1)
Reply 100 of 108, by Genju
Hm, thanks for the tip, but now I'm stuck with these errors:
../../../include\dosbox.h:25:1: error: unknown type name 'GCC_ATTRIBUTE' GCC_ATTRIBUTE(noreturn) void E_Exit(const char * message,...) GCC_ATTRIBUTE( __format__(__printf__, 1, 2));
/include\dosbox.h:32:9: error: unknown type name 'Bitu' typedef Bitu (LoopHandler)(void);
For what it's worth, I'm using msys2 x86_64 with the clang compiler.
Reply 101 of 108, by Serious Callers Only
weird, it's applying fine on my ppa and it was built 3 days ago.
Applying patch /home/buildd/build-RECIPEBRANCHBUILD-2530369/chroot-autobuild/home/buildd/work/tree/recipe/debian/patches/voodoo_gl.diff
patching file include/GL/gl.h
patching file include/logging.h
patching file include/Makefile.am
patching file include/pci_bus.h
patching file include/video.h
patching file include/voodoo.h
patching file src/cpu/paging.cpp
patching file src/debug/debug_gui.cpp
patching file src/dosbox.cpp
patching file src/gui/sdlmain.cpp
Hunk #1 succeeded at 2693 (offset 11 lines).
patching file src/hardware/Makefile.am
patching file src/hardware/memory.cpp
patching file src/hardware/pci_bus.cpp
patching file src/hardware/pci_devices.h
patching file src/hardware/voodoo.cpp
patching file src/hardware/voodoo_data.h
patching file src/hardware/voodoo_def.h
patching file src/hardware/voodoo_emu.cpp
patching file src/hardware/voodoo_emu.h
patching file src/hardware/voodoo_interface.cpp
patching file src/hardware/voodoo_interface.h
patching file src/hardware/voodoo_opengl.cpp
patching file src/hardware/voodoo_opengl.h
patching file src/hardware/voodoo_types.h
patching file src/hardware/voodoo_vogl.cpp
patching file src/hardware/voodoo_vogl.h
Reply 103 of 108, by Serious Callers Only
There is a mistake found by the dosbox-core fork for retroarch on this patch :
https://github.com/realnc/dosbox-core/commit/ … 49b3d646d031541
There is also this but i suspect it's irrelevant for non libretro environments:
https://github.com/realnc/dosbox-core/commit/ … e623e6be20a8636
edit: or maybe not now that i think about it, if it was in the original, it can't be about the libretro api; confirmed it's a original bug.
Reply 104 of 108, by Yesterplay80
I just applied those two fixes to kekkos part of kjliews combined patch. I'll update ECE with it when a new SVN comes out.
My full-featured DOSBox SVN builds (without debugger) for Windows: Vanilla DOSBox and DOSBox ECE (Enhanced Community Edition)
Reply 105 of 108, by rpint
Yesterplay80 wrote on 2020-05-15, 10:42:
Thanks for keeping this up to date for the rest of us, it's very much appreciated.
I'm attaching a tiny patch that also looks for glide2x.ovl in the user config directory (e.g. ~/.dosbox). This was more convenient for me than moving files to the system. Perhaps it's useful to you, too.
Reply 106 of 108, by kekko
Hi everyone,
I found some time to set up again my compiler environment.
This is an updated patch against current svn.
- fixes minor compiling issues
- fixes a major video memory leak in Quake2 and Descent2
Quake2 uses sort of dynamic textures for realtime lighting, changing existing textures thus invalidating textures cache and forcing to reload them.
Descent 2 writes to existing textures for animations and fonts.
The fix adds a glDeleteTextures in function voodoo_ogl_texture_clear, which is called when a texture is invalidated due to a write.
There is still a performance issue because of texture caching during explosions or gun firing.
If anyone has an idea of how efficiently handle textures in the above scenarios please let me know here.
Reply 107 of 108, by Serious Callers Only
@kekko, i just updated the patch to the latest version on the ppa, and it failed building. I think it's because of a path separator thing in a header include, and i'm going to edit the patch to see if it is, but i thought you should know:
https://launchpadlibrarian.net/486219180/buil … BUILDING.txt.gz
(search for 'compilation terminated')
I don't know if the forward slash also works in windows, but i have the idea that it's possible and it would be something where the compilers would prefer to allow.
Reply 108 of 108, by Serious Callers Only
Another:
https://launchpadlibrarian.net/486353544/buil … BUILDING.txt.gz
the 'expected' typedef or define seems to be (from grep):
src/debug/debug_disasm.cpp:typedef Bit32s INT32;
since this appears to only be defined in the debug path i'm not sure how it even compiles in other places, if it even does. I'm reverting to the old version until these linux miscompiles are fixed.
