First post, by Mostro
I'm attempting to use Dosbox to install the 7th Guest. I used the guide from the Dosbox Guide forum but encountered a problem. Everything works fine until I get to the install screen. When I hit any key to begin installation a Warning! pops up saying the 2nd disc is not int he drive. The 2nd disc is definitely in the drive, so I'm not sure what the problem is. My CD-Rom has never not read a disc correctly so that's not the problem. Any help is appreciated.
