First post, by alexclaudiu2003
does anyone know how I can turn off this annoying message?
Program Requires MS-DOS Mode
may not run well unless it is run in MS-DOS mode. Do you want to change its shortcut properties to make it always run in MS-DOS mode?
appears in very few games, an example is Prehistorik 1
The OS is Windows Millennium
Reply 1 of 13, by BloodyCactus
run the game from real dos instead of windows. problem solved.
Reply 2 of 13, by derSammler
Not sure if it was in the registry or in an .ini file, but Win9x has a list of files that will trigger that message.
Reply 3 of 13, by alexclaudiu2003
I searched a lot and found nothing on how to disable that message,
after pressing NO, the message disappears and the game works perfectly.
To run in real dos, it means shutting down all applications and boot to ms-dos from cd,
instead to click, play, play another game, listen music, etc.
Reply 4 of 13, by dr_st
It just means that it suspects it won't work well. If it works well, just leave it be.
Reply 5 of 13, by Tiido
Go to program properties and untick the warning message and perhaps tick "prevent ms-dos progams from detecting windows", a PIF file is saved that windows will use next time.
Reply 6 of 13, by Caluser2000
Let win9x run it from does or go directly to the Dos prompt and run it.
Reply 7 of 13, by Grzyb
Isn't it amusing that MS-DOS Mode is suggested by Windows ME, which... lacks MS-DOS Mode? 😁
Yet another example of how screwed up ME is...
Nie rzucim ziemi, skąd nasz root!
Reply 8 of 13, by dr_st
WinME doesn't lack MS-DOS mode; it just lacks the ability to boot into pure DOS without running Windows first.
Reply 9 of 13, by Grzyb
dr_st wrote on 2020-05-23, 09:03:
You mean Windows ME in its original form, without any patches or special registry settings?
If so, then how to access that MS-DOS Mode? Does it allow to load DOS device drivers?
Reply 10 of 13, by dr_st
Apologies; apparently my memory deceived me. Indeed the "restart in MS-DOS mode" is not available in WinME (without hacking). I rarely used this mode at all (even in 98SE), and somehow I thought it was still around.
Reply 11 of 13, by alexclaudiu2003
I meant if that message in the image above it can be hidden or disabled from an advanced setting of the operating system because after closing the message, the game runs perfectly.
Reply 12 of 13, by Kalle
Windows 98 did offer options regarding the MS-DOS mode (by default, "Suggest MS-DOS mode" is ticked, which is very likely the option that triggers the message you're getting).
Win ME however got rid of those advanced options (they used to be in the program tab, after you rightclick the exe and select properties), but the information inside the pif file is still there. I don't know if a standalone pif editor exists for 9x, but you could also edit it with a hex editor, basically it's 1 byte you need to alter.
You'll find it in the "WINDOWS 386 3.0" section, offset 0x29 from the beginning of this section (so if it starts at 0x187, you'll find the byte at 0x1B0). Change it from 00 to 04, that should do the trick.
