DFI CA-64TC MOSFET type?
First post, by dionb
This weekend I hit the jackpot - sort of: a cheap Tualatin-supporting board with ISA slot. Of course there was a catch: it's a DFI CA-64TC and it's dead. Now, as with all DFI boards from that era, it's a bulge-fest with crap-tastic G-Luxon caps. No problem, I know what to do there and have nice new Panasonic and Nichicon replacements lined up.
But...
It's also missing a MOSFET. Odd, as it's otherwise undamaged as far as I can see, but it's clear there used to be a MOSFET there and there isn't any more. Here's a stock pic of a board with the MOSFET present:
The attachment mosfet.png is no longer available
Can anyone with a CA-64TC (any revision - mine is rev B1 but they all have something very similar there) confirm what type of MOSFET is at that location?
The other two of the same size on my board (next to the ATX connector) are Philips/NXP PHB95N03LT. Would it be the same?
Unless I'm mistaken I used to cycle past the factory that made those on the way to work when this board was made 😜
Reply 1 of 5, by Horun
dionb wrote on 2020-05-19, 17:01:
Do not have that exact board but do not think that would be same MOSFET as the other two, the others are in a switching VRM (the coil gives that away) for the CPU. There is no coil in the circuit near the missing one so most likely a different power Mosfet or even a V Reg (for the DIMMS). One of my boards is similar and has a Lintek LV1084 near the DIMMS (is a variable 5Amp power v.reg chip). Not saying the chips are same but the location and support chips around are similar. Cannot find any good closeups thru Google....
Reply 2 of 5, by flupke11
I have both revision A1 and B1.
On my revision A1, that Mosfet is not present, although the solder landings for it are prepared. The IC in the far upper right corner is also not populated.
On the revision B1, the Mosfet element is present:
PHB
55N03LTA
PHm 0122 A1
as is the IC next to it (towards the corner):
Texas Instruments
13DFXXK
HC74
The two large MOSFETS near the coil and the at the lower end of the serial ports are:
PHB
8383N03LT
PHm0109B6
Reply 3 of 5, by dionb
Horun wrote on 2020-05-20, 00:36:
Nope, looked and this was about as good as it got. Thanks anyway.
flupke11 wrote on 2020-05-20, 06:22:
I have both revision A1 and B1. […]
PHB
55N03LTA
PHm 0122 A1
Texas Instruments
13DFXXK
HC74
PHB
8383N03LT
PHm0109B6
Thanks. TI IC is also not present on my board, so I suspect that the MOSFET may be missing by design. Still looks like something was there though...
Have now replaced the dead caps and tested, but board dead as a doornail. Will re-flash BIOS tomorrow to see if that was the problem.
Reply 4 of 5, by Horun
Hmm Good luck on re-flash. well the 55N03LTA is a high amperage Mosfet but cannot find any info on the TI 13DFXXK. Is like the chip never was, not even a old link. Very strange.
Reply 5 of 5, by quicknick
I think that's a date code or something like that, and the chip is a 74HC74.
