First post, by jamesp15
I was recently given this Voodoo2 with a very blown memory chip.
Outside of the very obvious chip that is blown, I do not see any other physical damage (but my very tired eyes may deceive me, so asking second opinions here.)
Should I replace all 4 chips in that bank? or would it be enough to replace just the blown chip?
I have sourced some "100mhz" EliteMT chips, I know its Mosel "90mhz" chips on there now, would that make any real difference? (I know it will run at whatever the card is set to, most likely 90mhz, was just thinking if there might be some timing issues or the like if I replaced just the one chip)
Also have to give the card a very thorough Isopropyl bath and toothbrush scrub, it has a layer of grime stuck to it.
Click on image for full res versions, if you need higher res I can scan the card in my scanner.)
