Reply 34221 of 52819, by Miphee
I just couldn't resist!
    1.26 MiB
    919.17 KiB
Reply 34222 of 52819, by phantom_pl
newtmonkey wrote on 2020-05-27, 17:34:
Sound Blaster 16 CT1740
It was listed as untested/not working and I got it for a steal. Sadly, it's got one of the "hanging note bug" DSPs.
Even more sadly, it doesn't seem to output anything on the left channel. It might just be a matter of applying some contact cleaner to the speaker OUT jack, but since it's got the hanging note bug and since I use external MT-32/MIDI I'm not really inclined to replace my AWE64 just to get better FM music. I'll store it away for now and revisit it at a later date, once I eventually get a dedicated MPU card clone, etc.
Silence on left channel might not be the case of dirty jack. It may be dirty jumper block (had the same issue on my SB16 SCSI).
As far as I can remember there are jumpers J1 and J2, and they are feeding the sound directly to the jacks (one is for he right channel, second for the left one).
If this jumpers are oxidized, they might not make contact, and cause the silence on one channel.
Try to clean them first.
Reply 34223 of 52819, by newtmonkey
phantom_pl wrote on 2020-05-29, 11:48:
Thank you for the advice! I'll try this.
Reply 34224 of 52819, by Tetrium
appiah4 wrote on 2020-05-28, 16:01:
Well, not really a retro hardware, but whenever I score a decent retro hardware scrap pile I find myself lacking a dozen of thes […]
Well, not really a retro hardware, but whenever I score a decent retro hardware scrap pile I find myself lacking a dozen of these, so I bought some..
Do keep in mind that not all cases use the same standoff height. This was some unexpected problem I once ran into and I didn't even know these came in different heights till I had issues caused by this (I was assembling a new rig) and I put them side by side and saw they were not created equal 😜
My retro rigs (old topic)
Report spammers here!
Reply 34225 of 52819, by derSammler
Aren't these the threaded screws that go into VGA, serial/parallel port connectors, etc. anyway? Stand-offs for a mainboard are higher and also normally a bit thicker and copper-color. I've never had a case where you could use the ones pictured. (well, you probably can, if you don't mind any cards not going fully into the slots)
Reply 34226 of 52819, by imi
I wish all computer screws were just metric... it would be soo much easier to find replacements x3
some recent stuff...
I assume a míro? Crystal with AVGA1 and IBM 8514 compatible F82C481, card is marked "BIBM-CRYS-204" on the back
and a SPEA Mirage P64 VLB with S3 Trio64 :3
...speaking of, it's missing one of the standoffs
424.02 KiB
a FAST capture? or TV out card? the SAA9051 suggests inputs?... not much info on that one has a S-VHS add on board and a feature cable.
and a V7 VEGA VLB
577.76 KiB
Geforce 2Ti and a Gainward Dragon 4000 Voodoo Banshee
517.62 KiB
Reply 34227 of 52819, by appiah4
Tetrium wrote on 2020-05-29, 12:05:
They are not motherboard standoffs.. 😉
derSammler wrote on 2020-05-29, 12:12:
Yes, they are exactly this.
Reply 34228 of 52819, by Katmai500
Someone scored a killer Diamond Stealth 64 VRAM VLB (S3 Vision 968) card with box and original floppies yesterday on the bay. I'm hoping to see it pop up in here soon.
Reply 34229 of 52819, by mpe
Also bought this 120W pico-ATX PSU for quick bench testing of motherboards without having to use AT/ATX PSU.
Seems to be working when using my 12-24V 3A power adaptor I use for my soldering iron. Hopefully, I won't blow anything with it.
Blog|NexGen 586|S4
Reply 34230 of 52819, by MMaximus
ShovelKnight wrote on 2020-05-29, 09:37:
Bought one of those black Startech Socket 370 coolers. Hopefully the fan is not too loud, but even if it is, I have a spare Noctua low-noise adapter to tame it.
I got two of these, they're a bit too noisy for my taste! I've just replaced the fan on one of them with a Noctua A6x25 FLX and it's much better - and when used with the optional low-noise adapter the noise almost disappears completely.
Hard Disk Sounds
Reply 34231 of 52819, by newtmonkey
Although my CH Flightstick Pro works fine, its inability to handle simultaneous button presses (firing missiles in Wing Commander, for instance) began to annoy me, so I got this:
After a quick wipe-down it's in fantastic condition and I just verified it works fine. I got it for a steal, too, 100 yen plus shipping!
Reply 34232 of 52819, by yawetaG
imi wrote on 2020-05-29, 14:21:
Expensive/monstrous Windows 3.x-based capture card, but I'm not sure how useful it is without the software and break-out cables.
Reply 34233 of 52819, by ShovelKnight
MMaximus wrote on 2020-05-29, 22:26:
Thanks, it's good to know. I usually use Noiseblocker fans because they're just as quiet as Noctua, but I can get them locally with free delivery.
Reply 34234 of 52819, by Deksor
Received this nice IBM PC 320 motherboard 😀
And it POSTs with no issues !
Reply 34235 of 52819, by ShovelKnight
AOpen AW37
I think CrystalFM (in its non-broken iteration) sounds great, the audio quality of CX4237 is better than most ISA sound cards, and I just happen to like AOpen stuff.
1.24 MiB
GPL-2.0-or-later
Reply 34236 of 52819, by Nexxen
newtmonkey wrote on 2020-05-30, 03:53:
Although my CH Flightstick Pro works fine, its inability to handle simultaneous button presses (firing missiles in Wing Commande […]
Basically the price of an umbrella 😀
Nice piece!
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
Reply 34237 of 52819, by Horun
appiah4 wrote on 2020-05-29, 14:38:
I have a bunch of brass and steel screw in standoff's. Yes they are fatter/wider but not always taller, many are shorter (overall length) than the backpanel cable screw mounts.
Won a bid on a working DFI socket 8 mobo with both a 200/256k and a 200/1Mb p.pro cpu's.
Reply 34238 of 52819, by imi
ah nice, my first joystick was the FCS Mark II, I got it in 1996 I think and still have it, but it suffered a bit over the years, the rubber has completely disintegrated.
Reply 34239 of 52819, by imi
got this nice package from the bay
míro DC30 and a Terratec Profimedia that is in nicer condition than the one I already had
also two nice MS DOS dome stickers and one of those DS12887 replacements from the same seller :3
525.96 KiB
oh yeah, and this Soyo SY-P4 I845PE ISA, P4 ISA board, one of the ISA slots is a bit crushed but I hope it's fine otherwise.
376.51 KiB
