First post, by gryffinwings
Hi guys, been a while since I've been here, but I need a hardware check on a future MS-DOS computer build, this is my first attempt at one and I'm getting parts that are easier to find, so it's going to be a Socket 7 system. The motherboard and the CPU I already have purchased. Also need information on parts to add ports for a mouse if that's possible or if I need an expansion card for that. Also any other recommendations for this build to make it a better MS-DOS experience would be appreciated.
CPU: Intel Pentium MMX 200 MHz
Motherboard: Elpina M537 (PCChips)
Sound Card: ESS ES1868F Audiodrive
Graphics: S3 Trio or Virge
Memory: 32 MB EDO
CD Drive
3.5” 1.44 MB Disk Drive
GOTEK Floppy drive emulator
SD to IDE Drive (8GB)
100997471_981591045629941_5466341264305684480_o.jpg?_nc_cat=105&_nc_sid=07e735&_nc_ohc=1B5WE7wlgGYAX-dJBOa&_nc_ht=scontent.fsan1-2.fna&_nc_tp=7&oh=85979cceb4156525b2f1f0ffbe48088b&oe=5EFD8EB6
101503619_981594095629636_4595566280316026880_o.jpg?_nc_cat=109&_nc_sid=07e735&_nc_ohc=KQFWYUGDIu0AX-Ki481&_nc_ht=scontent.fsan1-1.fna&_nc_tp=7&oh=687ddd1b8ac861879dd3d22d25fe7bb6&oe=5EFA3AE9
Main Computer: Custom - Intel 12900K, Asus Nvidia 3080 Ti, 64 GB DDR5.
Retro Computer: Packard Bell Legend I - AMD 286, 640KB RAM
Retro Computer: Shuttle XPC - Pentium 4 2.8 GHz FSB 400 MHz, ATi Radeon 9600 Pro, Sound Blaster Live!, 2GB RAM.
Reply 1 of 8, by jakethompson1
Look closely at those pins next to the keyboard port and see whether they are for a PS/2 keyboard or mouse.
You also need two serial ports on ribbon cables and a parallel port on a ribbon cable. The headers for those are right below the power connector.
You can always use a serial mouse. Whether you can use a PS/2 mouse or not depends on whether you have the connector for a port on this board.
Reply 2 of 8, by GigAHerZ
Where's the battery on this motherboard? Is that Huston Tech chip some non-standard curse like the DALLAS chip on many boards?
I would always recommend to try to find a motherboard that has a coin cell battery...
Reply 3 of 8, by gryffinwings
jakethompson1 wrote on 2020-06-02, 15:38:
Are these parts easy to come by on eBay? If so what do I call these things?
Reply 4 of 8, by gryffinwings
GigAHerZ wrote on 2020-06-02, 15:45:
It's a standard coin cell battery, and it has a cover, I posted another picture in my initial post to show what it is.
Reply 5 of 8, by GigAHerZ
gryffinwings wrote on 2020-06-02, 15:51:
Perfect! Looks good (Y)
With 8GB memory card, format it to 4x 2GB FAT16 partitions. Not all DOS software may be stable or working well with FAT32 file system. 😉
For pre-Win95, i usually go with 4GB cards, splitting them to 2 partitions, one for system and programs, other for installers and other files. This way i can always format the first partition, whenever i want.
Reply 6 of 8, by jakethompson1
gryffinwings wrote on 2020-06-02, 15:50:
This is the PS/2 version, you want something similar for serial and parallel. https://www.startech.com/Cables/Serial-Parall … Bracket~PLATE6F
You might have to move the wires around in the PS/2 connector depending on the pinout of your board. I'll let others speak to that
Reply 7 of 8, by Intel486dx33
Format a IBM floppy and copy over Microsoft “MSD” ( Microsoft system diagnostics ).
https://kb.iu.edu/d/agcs
Can help trouble shoot computer settings, conflicts, and performance.
Reply 8 of 8, by 1541
If you rely on nice midi music during games, try to get an ESS ES1868F with wavetable pins in order to connect a wavetable daugterboard like the "Dreamblaster S2 or X2".
💾 Windows 9x resources (drivers, tools, NUSB,...) 💾
