First post, by 386SX
some years ago I bought this converter and never used, thinking it was a CF to IDE adapter but not having CF cards to try it still seems a bit too large almost like those PCMCIA notebook format. What your opinion?
Thank
Reply 1 of 8, by chrismeyer6
That indeed looks like a cf to ide adapter to me
Reply 2 of 8, by imi
yep, looks like PCMCIA to me, probably for PCMCIA flash cards?
chrismeyer6 wrote on 2020-06-03, 16:18:
CF only has 50pins and is less wide.
this is full 68pins PCMCIA
you could probably just make it a CF adapter by using a CF-PCMCIA adapter though ^^
Reply 3 of 8, by chrismeyer6
Neat. I've never seen a pcmcia to ide adapter. Just pcmcia pci or Isa cards
Reply 4 of 8, by derSammler
That's a passive adapter, but PCMCIA is not ATA. This can't work, unless it's for special cards that may use the PCMCIA connector, but aren't PCMCIA cards.
Reply 5 of 8, by 386SX
I think that in the plastic bag sticker there was written CF/IDE adapter, can you imagine... It's indeed a passive adapter no active components beside the leds are on the pcb. But does a pcmcia to "memory" existed? I remember having a PCMCIA to PCI adapter that had sense, but this one I cannot understand the point of passing through the IDE connection...
Reply 6 of 8, by chrismeyer6
Have you tried inserting a cf card into it?
Reply 7 of 8, by 386SX
chrismeyer6 wrote on 2020-06-03, 16:43:
I've no CF cards since decades.. but I'd buy one for a retro machine disk alternative even if I think to remember CF cards to be much shorter. I had it on a Canon compact camera and I remember they were not that big. Between the two black guides there're 55 millimeters of space..
I wonder what config would have needed a PCMCIA to IDE connection... and without any converter just direct connection.
EDIT: I see on ebay there're many PCMCIA to CF adapters... then I might add a CF to SD adapter, SD to MicroSD adapter etc ... 😁
Reply 8 of 8, by imi
386SX wrote on 2020-06-03, 16:41:
yes, pcmcia flash was a format just like CF, just google, there's plenty of them.
derSammler wrote on 2020-06-03, 16:35:
yes it is PCMCIA, in fact that was one of it's original purposes, obviously this passive adapter doesn't support anything but ATA devices though.
https://en.wikipedia.org/wiki/PC_Card#History
SanDisk (operating at the time as "SunDisk") launched its PCMCIA card in October 1992. The company was the first to introduce a writeable Flash RAM card for the HP 95LX (the first MS-DOS pocket computer). These cards conformed to a supplemental PCMCIA-ATA standard that allowed them to appear as more conventional IDE hard drives to the 95LX or a PC. This had the advantage of raising the upper limit on capacity to the full 32M available under DOS 3.22 on the 95LX.[3]
