Reply 480 of 1037, by red-ray
- Oldbie
slivercr wrote on 2020-06-03, 22:35:[…]
- EDIT: "AUX Fan" should be "NB Fan".
- The changes you mentioned were correctly implemented
- I can now see the frequencies for the x1950 Pro
- RAM now shows as Single channel,
- temperatures have the correct name, although I still don't know what that high temperature is (not reported in BIOS, see attached screenshot)
- Weirdly enough, as I unplugged the Geforce2 MX the 12 V rail now reports a more credible voltage, in line with what the motherboard's own monitoring software reports.
- Its an old Samsung TV with VGA input, model UN32C4000PD.
- I have a couple other boards to test this on which should be more interesting for you.
- Thank you for checking out the test SIV and I have changed the fan name
- Good
- Yes, but the code only used the default values, please rerun the test with the attached SIV32X V5.49 GPUs-06 test SIV.
- Good
- I suspect that it's not used on this motherboard so have made it "go away"
- No, when I added MSI MS-7135 support I adjusted the scaling for VIN0 +12.
- May I have a screen shot of what the MSI utility reports.
- What locks does MSI utility use? From Menu->Windows->Processes Right/Click on the PID button and select Locks.
- Note: I expect the MSI software fails to use the Global\Access_ISABUS.HTP.Method lock so should in general not be used at the same time as SIV, see Menu->Help->Lock Handle to check.
- All of SIV + AIDA64 + CPUZ + HWM + … do use this lock so it should be OK to run them all at the same time.
- SIV should now report Samsung UN32C4000PD
- I look forward to seeing how SIV does on your other systems, what are they? Assuming they are running >= Windows XP you may as well use SIV32X V5.49 GPUs-06 on them.
- I should have fixed [Windows] to report AMD Turion 64 ML-42 (Lancaster) [SH-E5] 2.40GHz Socket 754
