First post, by Apolonius
- Newbie
Hi there.
I want to connect some modules to a Thin Client DOS based but, the sound card I use is the VIA VT8231 thanks to VIASBCFG.
So I have these options to connect the modules to the PC, via USB, COM port or Parallel port.
Through the USB port I have not idea how to do it, I suppose that there is no cable USB -> MIDI with DOS drivers so is discarded. Is there a chance to connect it through COM or Parallel ports?.
And for Windows 98, is there any chance to connect it with the UM-ONE MKII?, officially the driver for this cable don't support W98, but I don't know if is there a custom driver or anyhing else. I have to buy some old cables with compatibility on W98?.
Regards.
