First post, by Almoststew1990
 - Oldbie
My AT PSU died a while back and I am looking for a replacement.
I specifically need a -5v rail for my Sound Blaster 2.0, the rest of the specs I'm not too fussed about as this is powering a 386.
However I've recently discovered that -5v rails are not exclusive to AT PSUS. For instance I found a fairly modern ATX Thermaltake XP55 430watt PSU which has a -5v. Is there any reason why the Sound Blaster wouldn't work with this PSU?
I've got the necessary AT ATX power switch adapter.
