Reply 34620 of 57733, by CMB75
The form factor of this thing is very nice, indeed.
Reply 34621 of 57733, by OMORES
@chrismeyer6 - will do. 😀
@ CMB75 - Yep, this board will go in some tiny barebone case.
I have also to clean up those simms, didn t check their capacity but for sure there can t be only 1664kb.
Be kind, rewind... to YouTube
Reply 34622 of 57733, by devius
Lovely motherboard!
OMORES wrote on 2020-06-16, 13:22:
It's probably 2048KB but 384KB are reserved for the system or something so the BIOS decided to not include it in the startup screen.
My Schneider 386SX is the same. It shows the RAM as 640KB Base + 384KB Hidden + 1024KB Extended.
Reply 34623 of 57733, by cyclone3d
devius wrote on 2020-06-16, 08:29:
Ozzuneoj wrote on 2020-06-15, 20:27:
Very nice stuff! Lots of NIC filler but definitely some goodies...
What do you mean "filler"? Am I the only one that likes network cards, especially if they're ISA and from 3Com? 😅
I too like 3Com cards. Not sure about any of the others.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 34624 of 57733, by OMORES
devius wrote on 2020-06-16, 13:44:
Lovely motherboard!
Hmm... it looks that this SIMMs are equipped with 2x256K chips (x8) - so it should have 4MB, it would make sense for a late 386 system.
Reply 34625 of 57733, by pentiumspeed
2mb. 4 x 256kb = 1mb x 2 is 2mb.
4mb will be 4 simms.
cheers,
Great Northern aka Canada.
Reply 34626 of 57733, by devius
OMORES wrote on 2020-06-16, 15:40:
Those chips are 256K x 4bit, so two of them make 256KBytes per SIMM, hence 2MB.
Reply 34627 of 57733, by 386SX
I would like those late 386 mobo still having the PGA socket. The look of the PGA DX40 is much much better of the plastic one.. In my 386 mobo I've both the cpu soldered and the cpu socket (empty) and I still can't understand how and if it would be capable to understand which use of the two cpu if I'd install the PGA one.
That form factor with both cpu and fpu sockets and 256Kbyte cache support would be nice. Too bad I had in the past a Soyo mainboard exactly as I would like nowdays but had serious problems caused by the battery acid and I don't have it anymore.
Reply 34628 of 57733, by CHiLL72
I bought a Roland RA-50 Realtime Arranger last week that arrived a few days ago:
The attachment Roland RA-50.jpg is no longer available
I haven't tried it yet, but it looks fine and I'm told it works well too.
And today I also received the Athlon 64 3700+ (socket 754) that I recently found for a reasonable price. That will be going into my fastest Windows 98SE system with AGP. The mainboard is an MSI with NForce3 chipset, which has a blown cap that I need to replace first. It still works, but only boots intermittently. Should be fine once I put the new cap in.
The attachment Athlon 64 3700+.jpg is no longer available
Waveblaster MIDI boards: https://waveblaster.nl - online now!
Reply 34629 of 57733, by darry
CHiLL72 wrote on 2020-06-16, 18:58:
I bought a Roland RA-50 Realtime Arranger last week that arrived a few days ago: Roland RA-50.jpg I haven't tried it yet, but it […]
I just ordered an RA-50 as a backup if my MT-32 ever dies and also in the hope that it might support CM32L effects (not clear if it does, I won't be disappointed if it doesn't) . The price was too good to pass by at 113 $CAN (about 83 $US) shipped . The kicker is that the seller is so close that it would have been a short bicycle ride to pick the unit up in person .
Anybody run any conclusive tests on CM32L compatibility (or lack thereof) ?
Reply 34630 of 57733, by cyclone3d
Finally bit the bullet and ordered a couple Gotek floppy emulators..... this will let me clear out a dresser drawer full of 3.5" floppy disks. I'll probably keep some floppy disks for testing purposes but I really don't think I need hundreds of floppy disks.
Once I decide I want to go all Gotek that will also let me get rid of almost all my 3.5" floppy drives. I'll just keep a few for imaging disks and testing.
I really wish there was a 5.25" to USB adapter so I could hook up 5.25" drives to a newer computer for imaging purposes.
Also bought 20x 128kx8 10n and 20x 128kx8 15N DIP-28 SRAM cache chips.
YMF7x4 Guide
Reply 34631 of 57733, by cyclone3d
darry wrote on 2020-06-16, 19:16:
Nice! The RA-50 craze seems to have started. I've seen a few people on here that have also gotten one recently.
I got one a few days ago but haven't had the chance to hook it up yet.
YMF7x4 Guide
Reply 34633 of 57733, by dionb
Want to guess what I bought?
The attachment 15923374746340.jpg is no longer available
No, not a huge roll of 4.7k resistors. I didn't have a clue why I received this until I eventually unwound them and found this inside:
The attachment 15923374836381.jpg is no longer available
I ordered these batteries to fix up some motherboards and an SRAM floppy emulator with barrels of death. But why on earth the seller used ~220 4.7k resistors I did not order/pay for as wrapping is a mystery 😜
Edit: and they're the wrong bleeding batteries too 🙁
I ordered 3.6V LIR rechargeables, these are 3V CR non-regchargeables.
Reply 34634 of 57733, by darry
dionb wrote on 2020-06-16, 19:58:
Want to guess what I bought? 15923374746340.jpg […]
I ordered these 3V lithium batteries to fix up some motherboards and an SRAM floppy emulator with barrels of death. But why on earth the seller used ~220 4.7k resistors I did not order/pay for as wrapping is a mystery 😜
I guess the seller just could not resist 😉
Reply 34637 of 57733, by dionb
Maybe it was compensation for the incorrect battery...
Reply 34638 of 57733, by darry
dionb wrote on 2020-06-16, 20:10:
Or maybe he thought they would help the batteries resist shipping damage . (OK, I'm shutting up).
Reply 34639 of 57733, by dionb
darry wrote on 2020-06-16, 20:19:
With all these babies in parallel, resistance would be pretty futile anyway.
