Reply 15940 of 27537, by brownk
- Member
Recapped and played a MT-32. It sounds a lot clearer and sharper. I put two higher voltage rated caps at input filter C40, C41 and somehow the voltage regulating MOSFET on the right wall gets hot at the first power up. After some minutes of playing, it cools down to a slightly warm temp. I suppose it's time to replace the MOSFET with a resilient, modern component.
Other than that, it looks to be back in its old place.
