HWiNFO support of vintage hardware
Reply 382 of 683, by repaxan
On my ECS NForce4-A754, the NB chipset fan is incorrectly reported as the CPU fan.
    NFORCE4-A754.rar
    43.08 KiB
    61 downloads
    24.66 KiB
Reply 384 of 683, by repaxan
Asus P6T Deluxe with wrong voltage reporting.
I also noticed that when minimized and re-maximized sometimes this graphical glitch would happen.
    187.22 KiB
    p6tdeluxe.rar
    128.84 KiB
    63 downloads
Reply 385 of 683, by Mumak
repaxan wrote on 2020-06-19, 04:20:
Thanks, voltage values will be fixed in the next build.
But I have no idea why that glitch happens, haven't seen that yet.
Reply 386 of 683, by vorob
Hi, I'm again with my laptop Fujitsu Siemens Amilo Xi 1546. This time it's not about HWINFO (though it still reads weird 97C temperature from gpu sensor that doesn't exist)... I'm here to ask maybe you know how to solve my problem with faking temperature sensor, making it think that machine is over 90C? With that info computer force fan to ran on maximum speed, which is essential to save GPU from dying. I know that this thread is not about such weird stuff, but maybe you deep knowledge will guide me?
I've explained this in my own thread [REQ] Control laptop's fan via fake cpu temperature
ps. for some reason HWINFO doesn't read this sensor which is fooled via NHC app, but HWMonitor does see it.
Reply 387 of 683, by Mumak
vorob wrote on 2020-06-22, 20:20:
I assume you refer to the THRM sensor shown by HWMonitor. It's quite a simple fake via ACPI - the tool creates an ACPI Thermal Zone object.
Reply 388 of 683, by vorob
Mumak wrote on 2020-06-22, 20:44:
Yep, that's it. Any easy way to fake its values? Other then this horrible ancient app I'm using?
Reply 389 of 683, by Mumak
vorob wrote on 2020-06-23, 11:10:
I'm not aware of.. perhaps some other tool that can inject custom ACPI methods/tables, but I have never used one so can't recommend..
Reply 390 of 683, by dottoss
Hi Mumak, on my LGA 775 build with an q6600 there are some core temperature discrepancy between aida64, speedfan and HWiNFO. The two other is consistent while HWiNFO is reporting higher values. Attached you will find the debug file and below some screenshots.
244.72 KiB
    HWiNFO64.zip
    45.21 KiB
    53 downloads
Reply 391 of 683, by Mumak
dottoss wrote on 2020-06-28, 10:43:
This is most probably due to a different Tj,max assumption in different tools, but none of them knows this for sure. It's not possible to detect the correct value on older CPUs.
HWiNFO believes Tj,max=100 C for this CPU (which should be correct according to the specifications), others most probably think it's 90 C.
If you're sure it's not correct, you can change this by right-clicking on the core temperature in HWiNFO -> Adjust Tj,max.
Reply 392 of 683, by red-ray
Mumak wrote on 2020-06-28, 13:21:
AFAIK TjMax depends on the stepping and [B3] is 90°C whereas [G0] is 100°C. Given this I expect Speedfan + AIDA64 did not get updated for the [G0] stepping.
file.php?id=86950
    108.24 KiB
Reply 393 of 683, by dottoss
This is most probably due to a different Tj,max assumption in different tools, but none of them knows this for sure. It's not po […]
Cool, then HWiNFO is correct, which is good. That's the one more important for me 😀
Thanks
Reply 394 of 683, by hwh
Here's a K6-2.
Seems pretty normal. There's some OEM strings :p
Seems a little uncertain about the integrated graphics chip ("unknown"). I think shared video memory is 8MB, no less than 2MB definitely.
Drives not in system summary for whatever reason.
Here's the stuff.
(had to rename the debug file to post it here, remove the .log extension if necessary)
Reply 395 of 683, by Mumak
hwh wrote on 2020-07-23, 07:42:
Here's a K6-2. […]
Here's a K6-2.
Here's the stuff.
Thanks for the feedback. I have a fix for the Trident graphics, could you re-test it if I give you a new build?
Reply 396 of 683, by hwh
Mumak wrote on 2020-07-23, 08:54:
Here's a K6-2. […]
Here's a K6-2.
Here's the stuff.
Sure, I will come back to it.
Reply 397 of 683, by mastergamma12
I just noticed that for some reason, the newest version as well as the beta of HWINFO thinks that the 9700k in my htpc for some reason is an engineering sample when I got it from Microcenter and is an R0 based 9700k.
file.php?mode=view&id=88584
    9700k QS.LOG
    153.79 KiB
    53 downloads
    377.38 KiB
The Tuala-Bus (My 9x/Dos Rig) (Pentium III-S 1.4ghz, AWE64G+Audigy 2 ZS, Voodoo5 5500, Chieftec Dragon Rambus)
The Final Lan Party (My Windows Xp/7 rig) (Core i7 980x, GTX 480,DFI Lanparty UT X58-T3eH8,)
Re: Post your 'current' PC
Reply 398 of 683, by Mumak
hwh wrote on 2020-07-23, 22:39:
Here's a K6-2. […]
Here's a K6-2.
Here's the stuff.
Thanks, here you go: www.hwinfo.com/beta/hwi32_629_4219.zip
Reply 399 of 683, by Mumak
mastergamma12 wrote on 2020-07-24, 07:38:
I just noticed that for some reason, the newest version as well as the beta of HWINFO thinks that the 9700k in my htpc for some […]
It shows "Prod. unit", but QDF number instead of SSPEC. So your CPU is OK. Shall be fixed in the next build.
