First post, by Sektor88
One of my favorite Dos games. Now, I'm using a macbook pro. I downloaded the OSX DosBox and the game, and I have the OMF folder under applications. The thing is, it seems not to be accepting the command lines I give it. I did manage to mount applications to dosbox as the C disk, even though it still reads it as "Z". My questions are:
Can I even run OMF in dosbox on a Mac? I'm guessing I can, since OMF would be running inside the emulated environment.
What command line do I type in to gt the install.exe [or the .ini, i'm not sure which to use] to execute? Remember, I said I put the OMF folder in Applications.
And lastly, how can I access the game for future use? I'm guessing this one won't be too difficult...
EDIT got a little further, into the OMF directory at least. And it's saying that the INI files are corrupt. I have a disc of the game, too. i tired that, but to no avail. So...now what?
Thanks for your help!
Reply 1 of 3, by wd
Rank DOSBox Author
DOSBox Author
Don't know about osx, but basically you do something like this:
mount c /some/path
mount d /some/other/path/omfinst
d:
cd omf
install
Reply 2 of 3, by MiniMax
Rank Moderator
Moderator
60 seconds guide to getting your game to run in DOSBox
_________________
Reply 3 of 3, by Sektor88
alright, I'll try that!
