First post, by red
Hi, I downloaded the DosBOX .65 for run my old viewer of images on XP SP2, then when run the app called SEA.EXE all run great a little bit slow but run ok, the when see a full image the program show me only the half of the image and the other half show me a blue block 🙁 it´s don´t show me the full image...
Here the app:
//www.filegone.com/5uhw
Here the Screenshoot:
//img31.imagevenue.com/img.php?image=11983_02_239lo.jpg
Help!
Reply 1 of 3, by Qbix
Rank DOSBox Author
DOSBox Author
application uses some highres vesa mode.
Those are relatively new. Perharps they use some not emulated part.
Water flows down the stream
Reply 2 of 3, by red
So the app don´t will be run correctly?
