First post, by crazyzed
I just bought my first Roland gear. It is what would appear to be an old version, it doesn’t have a head phone connector. When checking the ROM version though, I found that it is version 2.00. I thought 1.07 was the highest version for the old unit?
Would this unit be considered a new version?
For compatibility, what’s the downside of 2.00 compared to 1.07?
I see there are 1.07 ROMs out for sale. Are they placed in a socket being easily changed, or does it require soldering? Could this unit even be downgraded below 2.00?
Reply 1 of 10, by keropi
interesting... can you dump this 2.00 rom?
maybe open the unit and take a pic of the mobo to see what is going on
Reply 2 of 10, by BloodyCactus
maybe you have a version right on the transition period. but sounds odd to me. pics would be great!
Reply 4 of 10, by crazyzed
I opened it up and got some pictures.
Serial: Z940799
Model: DM-32N-7
Just checked and it has the demo songs. From what I understand only the new version has those?
159.31 KiB
229.33 KiB
297.94 KiB
332.79 KiB
So what do you make of this?
Reply 5 of 10, by BloodyCactus
well the space is there on the pcb for the jack. its definitely a 'new' mt32, not 'old' mt32. for whatever reason they did not solder the jack on.
Reply 6 of 10, by yawetaG
BloodyCactus wrote on 2020-06-26, 19:55:
The casing itself is the 'old' version, hence no jack.
Reply 8 of 10, by BloodyCactus
yawetaG wrote on 2020-06-27, 09:53:
right. probably right in the transition period and used up old stock.
Reply 9 of 10, by jesolo
So, in theory, you could just drill a hole in the rear and solder on a jack? You would then have a complete MT-32 "new" with its headphone jack.
Reply 10 of 10, by yawetaG
jesolo wrote on 2020-06-27, 19:26:
So, in theory, you could just drill.a hole in the rear and solder on a jack? You would then have a complete MT-32 "new" with its headphone jack.
Quite likely.
