Compaq Presario 9538
First post, by khyypio
The attachment Case.jpg is no longer available
This is my friends old Compaq and I´m going to refurbish it for him. However, I could use a little guidance from people wiser than myself 😀
First, this is what I have to work with: The case is very, very dirty but otherwise it´s in excellent condition, no yellowing or bad scratches, so the outside parts will only receive a thorough cleaning. I will disassemble this computer completely and I´m going to paint the bare frame in almost similar beige as the case, it´s a little bit darker than the original beige because the store I visited didn´t have the perfect match but that´s fine. And yes, I will do it right with a proper primer and matt lack finish, it will NOT flake off! The hard drive is missing, but that´s fine because I would´ve replace it with an IDE2SD adapter anyway. I will also throw a SB Live! CT4830 in there mainly because I have an extra one.
Upgrades my friend made in the 90s:
- 200 MHz Pentium CPU
- Orchid Righteous 3D
- two 16 Mb SIMM sticks.
The attachment Moboandvoodoo.jpg is no longer available
This computer originally had Windows 3.11 but we agreed that Windows 95 OSR 2.5 would be a better option. There´s something that I´m a bit worried though, and what I could use a little help with: I don´t what kind of driver solution would be best for the integrated on-board chipsets, nor can I even find any. Here´s what we can see from the pictures:
-Opti Viper 82C556M, 82C557M and 82C558M
The attachment Opti Viper.jpg is no longer available
- graphics chipset S3 Trio64V+ H0C3CC and S3 Scenic/MX2 GOA3CC
The attachment S3.jpg is no longer available
- and sound chipset ESS Audio Drive ES1788F
The attachment Sound.jpg is no longer available
I will be updating this thread as this project proceeds to completion and there will be a new video in the end, of course 😀
Reply 1 of 37, by OSkar000
Intresting internal design 😀 Far from any known standards...
Old Compaqs are a bit odd but they are quite fun to work with. I have a few in my collection that Im trying to get back to life.
Reply 2 of 37, by PC Hoarder Patrol
Nice looking system 😀
The support files for these old Compaqs are normally remarkably easy to track down as all the SoftPaqs are still available online, both thru the HP ftp site and from the many independant mirrors of the same...e.g. this SoftPaq for the Trio64V+ is SP1879 (there may be newer ones as well) and supports Windows 95 on the Presario 9500 series. Here's a link to the readme file
ftp://ftp3.hp.com/pub/softpaq/sp1501-2000/sp1879.txt
Reply 3 of 37, by khyypio
Small update:
There was another chip hiding behind the modem
The attachment IMG_20200521_104640_01_01.jpg is no longer available
Here´s the stripped frame
The attachment IMG-20200520-WA0002.jpg is no longer available
And here it´s recovering from spray poisoning
The attachment IMG_20200522_103114_01.jpg is no longer available
The attachment IMG_20200522_103154_01.jpg is no longer available
Reply 4 of 37, by chinny22
This seems like a pretty good page.
http://www.driversguru.com/manufacturer/HP-pi … 63194%3E3768941
If you check the 2nd "Download Now" option for the driver (Not the installer) you can see its linking back to HP's FTP.
It may not have an individual page for the 9538 but alot say the 9500 series (alot of the time the hardware was the same across the series with a small change like a CPU the only difference)
earlier Compaqs accessed bios from a bootdisk/system partition, which if your missing the HDD you won't have. The "Personal Computer Setup" in the list from the site above looks to be what you'll need.
Compaq created their own motherboard chipsets but everything else (like the onboard sound/video) has a 90% chance of working with generic drivers.
I agree should be nice little project. Once you get the new HDD setup all working should be like running up any other PC
Reply 5 of 37, by khyypio
chinny22 wrote on 2020-05-26, 14:49:
This seems like a pretty good page. http://www.driversguru.com/manufacturer/HP-pi … 63194%3E3768941 […]
Thanks! This is very helpful.
Here´s a couple of new pictures:
The attachment IMG_20200604_130533_01.jpg is no longer available
The attachment IMG_20200604_130449_01.jpg is no longer available
Reply 6 of 37, by khyypio
I thought that by now this project would be finished with a video but a few parts are still on the way. So, here´s a little photo of my cabling solution.
The attachment IMG_20200608_094605_01_01.jpg is no longer available
Reply 7 of 37, by Pierre32
That's a fascinating case. I wonder what the design philosophy is behind that segregation? Whatever it is I like it. Cool project.
Reply 8 of 37, by chrismeyer6
That's a fun little machine. Beautiful job on the cable management. Looking forward to seeing the finished product!
Reply 9 of 37, by wiretap
Looks 95% the same as my Presario 9232. The one in your pictures appears to have the extra 1MB graphics RAM for the onboard Trio64 as well. There's a wavetable header on the motherboard you can use for MIDI in DOS with the ESS sound which is quite good. I put a Dreamblaster S2 in mine. Also, you can find the Compaq Presario 9548 Quick Restore CD on Archive.org which may work on the 9538. I ended up finding the quick restore CD's for my 9232 on eBay.. I believe it also covers the 9500 series, but you need to input your serial number which would normally be on the rear of the case just below the PSU fan exhaust.
My Github
Circuit Board Repair Manuals
Reply 10 of 37, by jakethompson1
Does the cd-rom give you any trouble opening or closing? If so the trick I found out on here about boiling the belt (or replacing it with an o-ring if it's broken) I've been able to revive several drives.
Reply 11 of 37, by khyypio
Well, here´s the deal: two months ago I ordered an SD2IDE adapter from some sort of importer in Finland which turned out to be just a rip-off. The order had to be paid in advance but the product never arrived, the guy doesn´t reply to my emails and he´s not returning my money. So I had to order it elsewhere and this project got delayed yet again. If not these setbacks, I would´ve finished this project and the video a couple of weeks ago. So, here´s couple of pics to show that this computer is coming together nicely:
The attachment IMG_20200610_150416_01.jpg is no longer available
The attachment IMG_20200610_150305_01.jpg is no longer available
wiretap wrote on 2020-06-12, 01:30:
Thanks for the tip, I´ll download that restore CD for sure!
jakethompson1 wrote on 2020-06-12, 21:33:
It indeed gave me trouble, but it started working after tinkering with it a bit. However, it turned out to be a painfully slow 4x CD-ROM so I decided to replace it with a 32X that I had.
Reply 12 of 37, by khyypio
I finally got the SD adapter and I bought a 16 Gb card for it. There´s a problem though: I don´t know how to boot this thing! 😁 Win95 bootdisk doesn´t work, Personal Computer Setup doesn´t work, I even tried partitioning and installing OS on another computer but it doesn´t help. I partitioned it into two C and D, both 7,5 Gb. Chinny22 said earlier that the new hard disk needs some sort of special boot partition. How do I do that?
Reply 13 of 37, by NautilusComputer
If the Compaq software to create the partition didn't work, all by itself, you'll need to boot from a floppy and likely do an 'fdisk /mbr' to write the Master Boot Record onto the SD. Might also need to mark a partition as 'active' in fdisk, too.
Reply 14 of 37, by khyypio
NautilusComputer wrote on 2020-06-25, 10:10:
I created a bootable floppy of the Personal Computer Setup executable but it doesn´t work. I can´t boot even to DOS with Compaq, I partitioned and formatted the SD card with another computer. So, preparing the SD card on another PC step by step:
1. I place the Win95 CD and Win95 bootdisk, and boot from the floppy
2. in A:, I go to fdisk, delete everything, create the new partitions (C as primary and D as extended, 7.5 Gb each)
3. I set C as active and escape to DOS and restart
4. I format C (format c: /s) and D (format d:)
5. Go to A:, and type "fdisk/mbr"
6. Swap the SD card into Compaq
Should everything be set at this point?
Reply 15 of 37, by PC Hoarder Patrol
I did kind of expect the Diagnostic/SETUP disk SP2141 to work as it mentions restoring 'a destroyed' diagnostics partition
http://cwcyrix.duckdns.org/ftp-archives/compa … 2500/sp2141.exe
http://cwcyrix.duckdns.org/ftp-archives/compa … 2500/sp2141.txt
so maybe try the previous version just in case
http://cwcyrix.duckdns.org/ftp-archives/compa … 1500/sp1363.exe
http://cwcyrix.duckdns.org/ftp-archives/compa … 1500/sp1363.txt
also might be worth trying the the aboves partner disk, Diagnostics/TEST, to see if the machine will at least boot
http://cwcyrix.duckdns.org/ftp-archives/compa … 2000/sp1986.exe
http://cwcyrix.duckdns.org/ftp-archives/compa … 2000/sp1986.txt
Hopefully you don't need a Recovery CD for this as they seem to be only available on request from Compaq
Reply 16 of 37, by khyypio
PC Hoarder Patrol wrote on 2020-06-26, 10:23:
I did kind of expect the Diagnostic/SETUP disk SP2141 to work as it mentions restoring 'a destroyed' diagnostics partition […]
Thanks! I´ll check those out.
Since this project turned out more difficult than I anticipated, I decided to make this a 2-part video: https://www.youtube.com/watch?v=kYdpuJPVYC8&feature=youtu.be
Reply 17 of 37, by Surrat
I'm also restoring a computer like this, mine is the 9548, but basically the same system.
These have an S3 Scenic MPEG decoder on the motherboard for watching full screen mpeg1 videos.
There is also an optional Compaq made ESS wavetable midi board to attach to the motherboard.
That compaq video ram upgrade is quite rare, it upgrades the built on S3 Trio64V+ from 1mb with 32bit access, to 2mb with 64bit access.
The Trio64V+ has no 3d functions, but its an excellent 2d card for dos games and windows.
The cacheable address range of the motherboard L2 cache seems to be 64mb from what I can find, so 2x 16mb simm, 2x 8mb simm, and 8mb built on, should max it out.
Not sure on yours, but the 9548 has EDO memory for the built on ram, so installing EDO simms will give the system a slight speed boost.
I was wondering if an i200 cpu would work, now I know it does.
I love your cable job! looks great! I hope mine comes out that nice.
I'm still in the hardware portion of the cleanup and rebuild, so havent hit any software problems, yet.
My plan is to run Win95c for dos and windows games.
That Orchid Voodoo1 is worth more than the rest of the computer, 🤣.
The Orchid model is the only V1 I have seen that uses all tantalum caps, so no cheapo electrolytic to dry out and make the card unstable.
HUGE thank you in this thread for the softpaqs, I will need the same ones!
Anybody know if there is a final bios update hidden in those softpaqs somewhere?
NuXT 8088, USIT Athena 286, Dell Powerline 486dx50 EISA, Dell Dimension XPS P166c DT, Dell Dimension XPS M200s, Compaq Professional Workstation 2x Xeon 550, HP Vectra XU120 2x P133 DT, HP Vectra XU200 2x PPro200, HP Kayak XU800 2x 1Ghz P3
Reply 18 of 37, by Surrat
These files are for a 9536, but I think will be useful on your 9538:
https://drivers.eu/PC/Compaq/Presario%209536
If your still unable to get the system to boot, could the floppy drive be bad, or perhaps the cmos battery is dead.
You might need to unsolder the battery and replace it, I have had to do that on a few of my other 90's compaq's.
Reply 19 of 37, by Surrat
On the baseboard, just inside of the floppy cable socket, check that component Q2 isnt damaged, or has its legs touching.
When you removed that heavy black tape, it hit that part and bent it over, can see it in the picture.
