Reply 34860 of 57733, by Horun
 - l33t++
darry wrote on 2020-06-27, 04:20:The point to all this is that parts from a smoking environment are not necessarily a significant issue, unless they come from the home of a chain-smoker who did not believe in ever opening a window .
Yes there is the "tar" effect from those that never opened a window ! Sorta like when I worked for a machine shop that did brakes and cylinder heads back about 1980. The junk that engines build up back then was crazy and took putty knifes and wire brushes to clean off before you even tried to do any work. Am actually glad that was one of my early college jobs, made me NOT afraid of crude build up in computers ;p
