Reply 34920 of 53198, by bearking
Bought this hightower AT case for about 30 euros.
181.99 KiB
It has a full 3 digit turbo display, and it is in a very good shape.
The seller said everything in it comes as a bonus!
1.52 MiB
So it has:
Gigabyte GA-586HX rev 1.56 mainboard
Pentium 100 MHz CPU + cooler
4 sticks of RAM, 48 Mb total
Some S3 Trio 1 Mb graphics card(with some issues)
Dawicontrol DC-974 PCI SCSI controller
2.1 Gb IBM SCSI HDD
some ALS100 Plus sound card
TEAC CD-56E 6x CD-ROM drive
FDD drive
Overall, I think it was a good deal. I'm happy for the case and also the mainboard...
Reply 34921 of 53198, by gdjacobs
wiretap wrote on 2020-06-01, 01:55:
Just won this Asus P2B-DS auction with a Make Offer deal for $119. (including RAM and CPU's) Now I can build my dually tually wi […]
Just won this Asus P2B-DS auction with a Make Offer deal for $119. (including RAM and CPU's) Now I can build my dually tually with two Upgradeware Slot-T slocket adapters. Going to load the beta BIOS, do the multiplier and voltage mods, then it should be good to go. I only have to modify one of my Upgradeware cards since it needs the 0 ohm resistor moved to enable SMP. Apparently my other is good to go from a previous owner since it is a rev 1.0 but already in the correct position.
I suggest trying NT 3.51. The amount of performance is hilarious.
Reply 34923 of 53198, by wiretap
gdjacobs wrote on 2020-07-01, 23:26:
I'll give it a try. I've used NT before (when I worked in a TV studio - the Globalstreams Trinity host used it), but I currently don't have any NT machines at home. It should be fun.
My Github
Circuit Board Repair Manuals
Reply 34924 of 53198, by cyclone3d
I have 35 motherboards and 75 cards on the way from that same seller I bought all those cards from before.... YAY!
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 34925 of 53198, by Horun
cyclone3d wrote on 2020-07-02, 02:16:
Good luck ! BTW I donated a bunch of my bad boards to him, hope those are not included in the batch 😁
(You do know they get them from someone 🤣): just kidding...
Reply 34926 of 53198, by deleted_nk
Bought this dual Pentium 3 lot sold as not working 2 months ago, one motherboard contains a matched pair of 1.13ghz Tualatin CPUs, the rest had 1ghz Coppermines
Two of the boards work, one has blown caps and a dead CPU I need to replace on it. Though the coolers got slightly bent up in shipping on the dead board, I'm sure I can straighten them out. Two boards also had a full 512MB installed, which on these boards, require at least two DIMMS installed for a successful POST. either way, fun times on Win2K or XP ahead...
Reply 34927 of 53198, by cyclone3d
And you can add the ISA slot to them if you want. My dual PIII Tualatin board has PCI and ISA but no AGP.
YMF7x4 Guide
Reply 34928 of 53198, by cyclone3d
Horun wrote on 2020-07-02, 02:21:
Heh.
Well, I think this is probably the last of it for now. From the sounds of it he was parting out a bunch of computers that he got from somewhere.
YMF7x4 Guide
Reply 34929 of 53198, by luckybob
ninkeo wrote on 2020-07-02, 02:45:
Bought this dual Pentium 3 lot sold as not working 2 months ago, one motherboard contains a matched pair of 1.13ghz Tualatin CPU […]
3 dual boards in one post? Yes please!
Reply 34930 of 53198, by deleted_nk
cyclone3d wrote on 2020-07-02, 02:54:
It could very well work, but I'm not that sure all the components are there to drive the ISA slot signaling, since there's a few missing transistors in that area. Could be worth a try just for the lulz on the one needing repair, if you know what I mean.
luckybob wrote on 2020-07-02, 04:18:
https://media.giphy.com/media/3EV74tm43smVa/giphy.gif […]
Some people might have sworn these off because they're VIA Apollo Pro 133T based boards rather than the Intel based equivalents, but to be honest, the working two are stable as a rock even running Win9x on one, and Win2k on the other.
I might do a build thread with either the Coppermine or Tualatin board, however I'm running short of GPUs that aren't MX 440s or 9250s. Might need to invest in a few proper GF4 cards, or maybe even Radeon 9000 series cards.
Reply 34931 of 53198, by CMB75
ninkeo wrote on 2020-07-02, 05:24:
I just did exactly that and it works perfectly with my AWE64 Gold.
Re: What retro activity did you get up to today?
Just drop me a note if you need any close up pictures of the supporting SMD components.
Reply 34932 of 53198, by CMB75
Just bought an “ASI Aquarius Intel 286-12Mhz PC” from the bay for roundabout 70 Euro, shipping included.
Needs some rework & retro brighting love but it seems to be in a decent condition already.
145.73 KiB
My first ever 286 😀
322.35 KiB
Back in the day I worked with 8088, 186, 386, 486, …
Reply 34933 of 53198, by imi
CMB75 wrote on 2020-07-02, 06:53:
My first ever 286 😀
I'm sorry for making you pay more :x
Reply 34934 of 53198, by CMB75
imi wrote on 2020-07-02, 07:25:
My first ever 286 😀
Sorry, I snatched it 😉 ...
Reply 34936 of 53198, by 386SX
Those looks great. I'd like to test some light linux like Lubuntu lxde i686 on those board to see how they would still be capable to run it. I think with a PCI SATA to SSD disk they'd still be good modern home computer. 😁
Reply 34937 of 53198, by CMB75
386SX wrote on 2020-07-02, 10:24:
I'm running period correct SuSE Linux 7.3 Professional on this kind of board without problems and with good performance - it supports gfxboot for a nice setup with 4 OS on one SSD (lilo-rewriting).
file.php?id=82776
Reply 34938 of 53198, by 386SX
CMB75 wrote on 2020-07-02, 10:59:
I'm running period correct SuSE Linux 7.3 Professional on this kind of board without problems and with good performance - it sup […]
file.php?id=82776
But even if not period correct, if I had such board I'd stress it a bit with a very modern linux distro and maybe one of the latest 5.x kernel to have all the possible component compatibilities. Obviously lxde is the fastest gui choice I'd make to help the system a bit. 😀
In the past I tested LXDE Ubuntu on a Athlon XP 3200+ and 2GB of ram and SSD and I could even use YouTube at quite good resolution. Obviously linux had no gpu acceleration for videos but OpenGL composition for the web rendering was possible and helped a bit.
