First post, by Mattyice1994
- Newbie
Hi everyone,
I've been trying to hunt down a good AT PSU.
Many of the options I find on Ebay have an attached switch already, but I want to use the switch that is already included in my case I have.
Can the cover of the switch be taken off (the white box), and would it reveal the standard 4 sheathed connectors?
Here's an example:
Also, I've been primariy trying to find a Delta (or an OEM PSU that is actually a Delta), or an Enermax or Astec.
Any other brand suggestions?
Am I doing the wrong thing by searching for an original AT PSU? I do like the idea of having a truly era-correct build, and I like the idea of restoring a PSU if need be. But, I know many people advocate for the ATX adapter to AT situation.
If I were to go for an ATX PSU, I am concerned that it wouldn't really have been designed with 90's hardware in mind.
Any advice on what I should be looking for, or where to find it would be excellent!
Thanks,
Matt
