Reply 140 of 893, by ragefury32
Socket3 wrote on 2020-07-13, 20:41:Here's my 2 cents: any K6-II laptop that matches your size requirements. Most K6-2 laptops run either the VIA MVP4 chipset with a Trident Blade 3D / Blade XP video card and ESS sound card or even a dedicated S3 Savage mobile chip. The Trident Blade 3D on board video witch has perfect dos compatibility and will 3d wise it can play quake 2 @ 640x480 at good framerates. It has good direct 3D and openGL support. The S3 Savage has perfect dos compatibility and rather good 3d capabilities considering it's paired with a K6. Some K6 laptops come with a SiS chipset with means you get a Sis 305 video card with again great DOS compatibility. Either way you can't go wrong. Can't speak for build quality or keyboard tough.
Another plus is that you can replace the K6-2 with a regular socket 7 pentium since the K6-2 (K6-2+ or K6-III+ usually come in laptops) is always socketed. Some machines allow for 2.8v - others don't. In any case you can use setmul to slow it down. You could even experiment with a Tillamook if you can get your hands on one.
Ehhhh. You don't really have that much size flexibility on K6 laptops - it's almost always a 5-8 pound ABS waffle iron, and the smaller screen on them either implies a bigger bezel, HPA (dualscan passive matrix, which is nasty), or both. I've never seen a K6 equivalent, to, say, a 3 lb Thinkpad 240 or a 4 lb 560E/X/Z.
I also did not recall seeing an S3 SavageMX/IX on a K6 laptop - the VirgeMX maybe (those are in the Toshiba 1600/2100 CD family), but machines with the SavageMX/IX tend to be out in 1998/1999, which are paired with Coppermine P3s as they are slightly later than the K6 days of 1997. Even for the SiS305s I am a bit doubtful about - I've seen SiS741 chipsets on Athlon/Duron laptops, but for the K6 period is mostly the SiS530s, which are SiS6326 based. The best GPU you can hope for in that vintage for a K6 is the ATi Rage Pro LT (which is like the Riva128 mobile). Of course, if you consider that the K6 laptops are considered "value" machines, I doubt that they are all that great. The K6 versions of the Compaq Persario 1200 series are known for brittle plastics and faulty power jacks even back in "the days"
