Dual Pentium Pro Build Thread
Reply 120 of 185, by H3nrik V!
red-ray wrote on 2020-05-19, 22:19:
luckybob wrote on 2020-05-19, 19:35:
I'd spend that much on that motherboard in a heartbeat. EXCEPT it doesn't appear to have the cpu support brackets. Something that can NOT be ignored with slot-2.
In years gone by I did and still have a boxed Supermicro S2QR6 4 x Slot 2 motherboard with all the VRMs + brackets + … sitting on the shelf waiting to be used. When I got it I was overly keen to have a four socket system, but as I now have HP DL580 G5 + G4 + Dell PowerEdge 6300/450 systems and suspect I will never use the S2QR6 , maybe it's time to put it on eBay.
Oh my, what a monster!
Reply 121 of 185, by Mentat-vvo
A Tyan mobo is about to accept dual PPros.
1.56 MiB
1.5 MiB
This HP/Compaq monster, unfortunately, needs exact info on the correct ATX power plug pinout or the original power supply unit. The PS unit from Dual Slot2 mobo from HP/compaq did not do the trick.
1.93 MiB
P.s.
A collection of PPro-capable BIOSes is extended by Asus P3B-F. If someone here have original Asus or other Slotket8, I can share the bios file. The P3B-F’s bios can even handle overvoltage up to 3.5v!
1.57 MiB
PPro250/Freeway694x/512M/Gf3Ti500/AdvGUS
2x P3Xeon900-2M/1Gb/QuadroDCC/AWE32
K6III+400@624/P5A/256Mb/GF3ti200@500
Iskra 1031 Issue 2 - i8086 PC/XT Clone from USSR
Reply 123 of 185, by Mentat-vvo
chrismeyer6 wrote on 2020-07-20, 13:06:
That's going to be a fun system once it's done. What are you using for cpu cooling?
AMD coolers (thin ones should fit) AM2 and compatible. Original ones are also supported, but I do not have them.
My slotkets are designed to have holes for the backplate.
1010.63 KiB
Reply 126 of 185, by PC Hoarder Patrol
Mentat-vvo wrote on 2020-07-20, 13:00:
Isn't that the motherboard from a Compaq AP550 Professional Workstation (it's an OEM version of the Intel OR840) - you can find info on the PSU and pinouts in this thread Weird Compaq Motherboard
Reply 127 of 185, by chinny22
So you'll have dual blacktops in the Asus board and dual goldtops in this.
You have a really nice dual dual PProp setup 😀
Reply 128 of 185, by gdjacobs
chinny22 wrote on 2020-07-21, 08:52:
Time to find a period copy of CATIA.
Reply 129 of 185, by donkom
Mentat-vvo - I signed up for an account on Vogons just for this thread. I'd absolutely love to purchase some of your slotkets and pick your brain about some crazy build ideas. What is the most modern chipset you've been able to get the Pentium Pros to function with? Any possibility of a Socket 8 - Slot 2 adaptation? Keep up the great work!
Reply 130 of 185, by gbeirn
Mentat-vvo wrote on 2020-07-20, 13:11:
AMD coolers (thin ones should fit) AM2 and compatible. Original ones are also supported, but I do not have them. […]
My slotkets have holes for the backplate.
Can you tell me a bit more about this? You reverse engineered a socket 8 slotket is that correct?
Do you have the gerber files available? Or the PCBs for sale?
I have dozens of NOS socket 8 sockets and would be interested in producing some of these.
Thanks!
Reply 132 of 185, by Mentat-vvo
donkom wrote on 2020-08-02, 22:49:
I believe Asus P3C-D is the most advanced mobo. Slot2 boards are so rare and are designed for the ideological successors of PPRos - P2 and P3 Xeons. No, I did not think about Slotket8S2. If one is interested in slotket8 - email me
sanastyuk@piboc.dvo.ru
Reply 133 of 185, by Mentat-vvo
maxtherabbit wrote on 2020-08-03, 04:32:
so did the tyan tiger with dual PPros work out?
Not yet, since I’ve found RED clone of ASUS P3V133 from Freeway. It is built on a VIA 694X chipset. Need to improve SuperPi result that Asus P3B-F could supply @ 2.5x100.
1.99 MiB
The Red one
1.53 MiB
Reply 134 of 185, by Mentat-vvo
gbeirn wrote on 2020-08-03, 03:46:
Can you tell me a bit more about this? You reverse engineered a socket 8 slotket is that correct? […]
Thanks!
Yes, I have reverse-engineered Asus C-P6S1 and no, I’m not going to share the gerbers or unassembled slotkets. Slotket8 itself is only a half of the PPro Slot1 system. It also needs a support from the BIOS.
Reply 135 of 185, by luckybob
can confirm, he won't let me see the gerbers either!
That OR840 board would be SO COOL to run with ppro chips. but I personally would keep my expectations at the 440BX chipset level as I doubt newer boards have the voltage regulatiors for 3.3v
Reply 136 of 185, by pentiumspeed
What's the reasons not disclosing the gerbers of this socket 8 slotkets? There are pretty good demand because people are still looking for all kinds of slotkets including high quality clone to make tualatin slokets without the issues of the previous low quality adapters?
Cheers,
Great Northern aka Canada.
Reply 137 of 185, by maxtherabbit
pentiumspeed wrote on 2020-08-09, 01:36:
Cheers,
I think the obvious conclusion is he intends to manufacture and sell them
Reply 138 of 185, by pentiumspeed
maxtherabbit wrote on 2020-08-09, 14:24:
Cheers,
I hope so! Not crazy price too.
Cheers,
Reply 139 of 185, by wiretap
But then he'll realize only a few dozen people will buy them if the price is fair. 🤣 .. it's better just to make gerbers for retro computer stuff public, as there's really not a whole lot of revenue in niche products. Someone will just buy one to clone/fork anyway.
My Github
Circuit Board Repair Manuals
