First post, by nwsw
Hi All,
I've got an interesting one for you. I've got a working system with the following specs that has had no issues running in 66mhz or 75mhz clock speed. I just got a PIII 933mhz Coppermine Slot 1 CPU to try and it's giving me issues. I believe it is due to the fact that I'm trying to run at 133mhz with 100mhz SDRAM, but the odd thing is it still gives me the same errors when I run the PIII at 100mhz (733).
Abit BX6 Rev 2.0
BIOS: 04/26/2000-i440BX-W977-2A69KA1JC-QR
PIII Coppermine 933mhz Slot 1
Geforce FX 5200 128mb AGP
4x256MB (1024) PC100 SDRAM (New from memorymasters)
With Windows 98, (old install and fresh install), I am getting a "While Initializing device VPICD Windows protection" error that forces a restart. This occurs on normal and Safe Mode. I've done the standard fixes and even reformatted/installed.
With Windows XP, I get a random BSOD when trying to install.
The processor works fine at the default 66mhz, it's just significantly reduced in speed. As I said before, it's got no trouble running various PII/Celeron CPUs at 66/75mhz. DOS seems to work fine. Any assistance is welcome, thanks!
Reply 1 of 9, by swaaye
My guess is you need to recap that Abit board. Abit boards usually had very poor quality capacitors back then. Can you post some photos?
Reply 2 of 9, by Joseph_Joestar
Windows 98 cannot handle more than 512 MB RAM without third party patches.
Remove the extra RAM and try re-installing.
Reply 3 of 9, by nwsw
Joseph_Joestar wrote on 2020-07-20, 22:35:
Hmm, that's odd. I've been running the same amount of ram (recognized at ~933mb) with my PII (Slot 1) and Celeron (Socket 370 with adapter) at 66/75mhz with no issues. It's properly recognized in 'dxdiag', etc. in Windows 98.
Reply 4 of 9, by swaaye
It should boot and seem to work fine with 1GB, but there are parts of 98SE that misbehave. Such as the vcache. So usually you should just go with <= 512MB.
Reply 5 of 9, by nwsw
swaaye wrote on 2020-07-20, 22:33:
Caps all look good, no leaks or bulges. I'll try to take a bare picture of the board later, but here's pictures from the eBay sale that I purchased it from:
https://www.ebay.com/itm/ABIT-AB-BX6-Slot-1-I … 872.m2749.l2649
I've recapped a lot of things, including a Game Gear so I think I would have spotted a bad capacitor, but who knows. 😀
Reply 6 of 9, by nwsw
swaaye wrote on 2020-07-20, 22:41:
Awesome, thanks for the info. I'll give that a try and report back. What about Windows XP? Does it have a RAM cap that I'm not aware of? From what I've been reading it seems some folks are saying that you need to run 133mhz SDRAM with a 133mhz CPU for the 440BX/Slot 1.
Reply 7 of 9, by swaaye
nwsw wrote on 2020-07-20, 22:44:
XP is fine all the way up to 4GB.
Running PC100 at PC133 is certainly not a guaranteed thing, and having 4 sticks reduces your chances. Try 1 stick at a time. 256MB is more than enough for Win9x gaming anyway. Keep the RAM latencies at 3-3-3. Bumping the RAM voltage might help too.
Of course the other problem with 440BX @ 133 MHz is that AGP unavoidably runs 89 MHz. Many cards don't like this.
You could make yourself a Memtest86/Memtest86+ bootable CD and see if tests pass alright. Also, Prime95 works with Win9x.
Reply 8 of 9, by nwsw
swaaye wrote on 2020-07-20, 22:53:
XP is fine all the way up to 4GB. […]
Thanks so much for the advice! I'll be busy this evening. 😀
Reply 9 of 9, by nwsw
Thanks for the help everyone. I was able to get Windows 98 to boot stable with 1 stick and Windows XP/Vista to boot with 2 sticks, both at 933mhz. 😀
