First post, by baldcoder
I have a DTK PTM-1000 286 motherboard. It was working fine, but I wanted to replace the CMOS battery because it was corroded. After replacing the battery, now I get a CMOS CHECKSUM FAILED! When I use CTRL-ALT-ESC to go into the CMOS setup, it doesn't respond to keypresses (except NumLock will toggle and I can CTRL-ALT-DEL to reboot). I can't actually change any values though.
Is there a way to clear the CMOS RAM or some other way I can recover this motherboard?
Thanks.
Reply 2 of 6, by Zup
Have you tried to use cursors from the numeric keypad?
I'm selling some stuff!
Reply 3 of 6, by baldcoder
I haven't tried either one, but I will and let you know the outcome. Thanks for the recommendations.
Reply 4 of 6, by baldcoder
The numeric keypads don't work in the CMOS setup.
I was able to boot to a floppy and run GSETUP. The first time, I just restored defaults and made sure the floppy drive was set to 1.44 and the display was monochrome. After rebooting, I got a REAL TIME CLOCK error.
So I ran GSETUP again. When I change the time field, it also changes some of the date fields as well. e.g. I entered 0102 for the time and the time field did change to 01:02:00, however the date field changed to 00/00/102.
Is this a bad RTC/RAM chip (MC146818A)?
Thanks in advance.
Reply 6 of 6, by quicknick
Have you tried using the DOS commands 'time' and 'date'?
