First post, by Neoda
Hi, Whenever I try and run Screamer in Dos box, I mount the cd drive and the hard drive, as I did when I installed it. Whenever I try and run it however, it always says cannot open file DATA\GEN.DAT . I've stopped it from being read only, however it is still archived if that could affect it. I've tried running Screamer with VDMS and Sapucdex, and it works fine on the first level, but on Mountan Pass and Lindberg it always crashes in the same place, with or without music and sound. I've tried older versions of Dosbox and the same problem come up.
