First post, by SpnInquisitor
I've got a problem installing W95 on DELL Optiplex GX1. I try to install the OEM 2.1 version but after booting the installation floppy there's an error message that no cd drive has been detected. The disk is spinning and activity diode is flashing so I think it should be working.
I probably didn't give enough info so if you need some I'm sitting next to the computer. I've opened it and checked all the IDE connectors and even replaced them with new ones but sadly, no results.
I also have one problem with my SD2IDE adapter. Activity diode flashes on the startup (when BIOS' loading) but then after the boot disk starts, the card is not active any more. This is not that much of a problem, 'cause I've got a few IDE hard drives, but I'd like to use the SD card. I've also heard on LGR about some software with which you can install an old windows onto an SD card from a modern PC.
Please help.
