First post, by wulp
Hello,
I have an IBM 5155 with is a TMC card. It has 2 serial ports, 1 parallel port, 256k and an RTC.
I can't find any information about that (e.g. how to set up the RTC).
Does anyone has information about that?
Thanks!
Reply 1 of 6, by Horun
The IBM 5155 is a nice XT luggable ! It uses a special utility to set time/date like the RTC in a Laser XT/3. I do not know the exact one needed but you could try the two included in the Laser XT utils: http://www.vogonsdrivers.com/getfile.php?file … &menustate=28,0
The two Clock / Time Set / Get utils are in the \XTutil folder. Maybe one of them will work....
I checked http://www.minuszerodegrees.net but could not find any RTC utils for IBM or other.
Reply 3 of 6, by wulp
@ Horum: Thanks! I see what works when I have it back in my possession ... He is now with a friend where there is now Covid in the house. I'll just leave it there for a while! ....
@ luckybob: Sorry, but with Photo resizer this is the smallest I get (19kb)
Reply 4 of 6, by wulp
Horun wrote on 2020-07-26, 20:41:
Hello,
I downloaded the file, tried to open it, but I got the message : Error - operation failed...
Reply 5 of 6, by Horun
What did you try use to open it ? It is 7zipped. Attached are the \XTutils folder with rtc apps from inside it and some generic RTC time utils from minuszero. Pkzip or RAR should open them.
    clkprogs.zip
    6.52 KiB
    30 downloads
    XTUTIL.zip
    41.98 KiB
    34 downloads
