First post, by kombatologist
Hi there. Just wanted to report a bug with Hydro Thunder (the standalone port, not MAT3). It was working perfectly up to version 2.54. As of 2.55, not so much.
dgVoodoo v2.54
dgVoodoo v2.64 (same settings)
My CPU/GPU specs if it helps:
Ryzen 7 3800X
Radeon RX 590
Reply 1 of 2, by ZellSF
It's a know issue with AMD drivers and newer dgVoodoo versions. Dege is working on a D3D12 render, which doesn't seem to have the same issue. See the WIP versions topic:
dgVoodoo 2.7.x and related WIP versions
