First post, by Braca862
Hello everyone,
I recently downloaded the DOS version of Kali from the maraakate website for my Windows 98 computer. However, I seem to not understand how to set up Kali for DOS; starting Kali gives me the error "no packet driver found". The documentation provided was too confusing to understand how to install ethernet drivers. I use a buffalo wli2-pci-g54s wireless card for connectivity.
Can anyone please help me?
Reply 1 of 3, by Jorpho
Braca862 wrote on 2020-07-31, 01:24:
Maybe you should explain what you found confusing? Otherwise someone might give you another explanation that you will find too confusing.
I think it's very unlikely you'll get that running in DOS.
Some of the DOSBox builds have network emulation; maybe you'd be better off with one of those.
Reply 2 of 3, by aleksej
You need full ver (not a demo) of NDIS3PKT driver which prohibited here due to warez.
Also you can try Kali95.
Reply 3 of 3, by Braca862
So I have installed the ndis3pkt driver. Now I no longer get the error I mentioned. However, Kali doesn't seem to load as shown in the attachment. Could it be because the drivers I installed are a demo?
