First post, by iVirtualZero
Hi i can't seem to find drivers for this Epox motherboard. There is an ISO https://archive.org/details/EPOX-6F01B0009 on this site but this specific motherboard isn't listed. I tried other sites but the drivers don't work. Does anyone know where i can download an iso for this?
Reply 1 of 4, by The Serpent Rider
That would be redundant. Just use VIA 4in1 driver pack and maybe dedicated driver for Highpoint 370 controller.
Reply 2 of 4, by PC Hoarder Patrol
These should be enough to get you started
Manual - https://web.archive.org/web/20020611013838/ht … 0/file/D3VA.PDF
VIA 4in1 v4.34 - https://web.archive.org/web/20020223015946/ht … le/4IN1434V.ZIP
HPT370 v1.11 - https://web.archive.org/web/20021104165144/ht … HPT370_V111.ZIP
VIA USB Filter v1.08 - https://web.archive.org/web/20030217120106/ht … e/VIAUSB108.ZIP
BIOS - https://web.archive.org/web/20020315103646/ht … le/D3VA1323.BIN
BIOS - https://web.archive.org/web/20030906162338/ht … le/D3VA1802.BIN
Reply 3 of 4, by iVirtualZero
Thanks will install these. Would this work on XP?
Reply 4 of 4, by PC Hoarder Patrol
The driver ZIP files cover all the main versions of Windows so you should be OK.
FYI, the BIOS files cover the following changes -
D3VA1323 - addresses issues with PS/2 keyboard, mouse and updates the HPT370 ROM BIOS from 1.03 to 1.10v
D3VA1802 - updates the HPT370 ROM BIOS from 1.10v to 1.11v
