First post, by ildonaldo
Please find here - due to the corona break- another (premature) build of mine 😉
Always (later) wanted a Rambus PC but never understood the fuss around Rambus ...
Board: Asus P4T, Intel 850 Chipset, Sockel 423, ATX
CPU: Pentium 4, Willamette, 1.5 GHz, Cooler with 60mm Lüfter
RAM: 1GB RDRAM (4x256MB), Samsung MR16R1628AF0-CK8 Rambus 256MB PC 800
2D/3D-Grafik: Hercules 3D Prophet 4500, 64MB, AGP
Sound: Creative Labs SB PCI 128 CT5803
HDD: IBM Deskstar 20.5GB, DTLA-305020, UDMA-100, 5400RPM
ODD: Hitachi GD7000 8X40X IDE DVD-ROM
FDD: 1.44 MB 3.5", Samsung SFD-321B
Case: NoName ATX
PSU: ATX 350W, Be quiet! Pure Power, BQT L7-350W
OS: Windows 98SE (inkl. Updates)
The attachment 01.jpg is no longer available
The attachment 02.jpg is no longer available
The attachment 03.jpg is no longer available
The attachment 04.jpg is no longer available
The attachment 05.jpg is no longer available
Building my own PCs since 1991 - for my retro builds it's "no CF-disks, no Floppy emulators, no modern cases etc.", only the real and authentic stuff whenever possible.
Reply 1 of 5, by Warlord
what a piece of history. nice transitional build.
Reply 2 of 5, by greasemonkey90s
from my testing the kyro2 does better in w2k as far as scores. Seems the w2k driver is better tuned then the 98se one.
Reply 3 of 5, by chinny22
Nice, still want a rambus pc in my collection.
Seems crazy to want a build based solely on the ram type but still want one.
Having the Kyro seems like a good excuse to also keep the build around 😀
Reply 4 of 5, by ildonaldo
I hoped to use it for my second Voodoo 5 5500 (AGP 2x) but unfortunately the board only supports AGP 4x.
... so I went for the Kyro II card.
I know that the Kyro II 4500 has some AGP bios bug but it works fine with the Asus P4T board.
Reply 5 of 5, by flupke11
Well balanced system. I also like Rambus builds, although for each system at a certain point in time, there's a better (but less exciting) system that can be built with common SDR-SDram or DDR-SDram parts.
I have a 232-pins i850 RDRam system which performs not as good as the i865/i875 systems I have, but the weird RDRam itself is a reason to hold onto the system 😀.
