Reply 180 of 212, by Benedikt
root42 wrote on 2020-08-05, 10:12:
Predator99 wrote on 2020-08-05, 10:01:
So this doesnt seem to work as epxected. It seems not to be possible to distinguish between 320x200 and 640x200 resolution based on HSYNC or VSYNC data. Its the same for both resolutions. There are only more pixels per line in 640 mode.
Need another method for this...
True, the distinction works only for 200 vs. 350 lines modes. 640 and 320 are the same modes just with a different pixel clock. However that’s a signal not available on the EGA connector. You could create a heuristic that tries to figure out the mode, but it will never be perfect.
Which is why virtually all emulators scale to 640x400 by default.
Theoretically, fancy software might even switch between 640 and 320 columns in the middle of the screen, e.g to mix the 640x200 2-color CGA mode with the 320x200 4-color mode.
Reply 181 of 212, by Predator99
Benedikt wrote on 2020-08-05, 10:17:
Yes, this is something I will try next: Draw each Pixel 2 times in 320x200. With this a 640x400 (or maybe 640x480) Window can be used for all modes without changing the window size. Will see if there is a high impact on speed which is still borderline.
640x200 doesent look very good at the moment anyway, but there are not that many games using it...if there is no way in autodetecting it maybe we can implement a manual change via keystroke...
Reply 182 of 212, by Deksor
Well if you want to have the correct aspect ratio, you have to stay with 4:3.
Best way of doing it is apparently to scale the image vertically three times and then scale it to proper aspect ratio with bilinear filter.
So if the image is 640x350, you'll have to scale it to 640x1050 then scale it down to 640x480
Here's how the POST screen looks like on a monitor
Here's the POST screen unscaled
8.62 KiB
and here's the POST screen scaled
15.04 KiB
Much better isn't it ? 😉
Same happens with games by the way
Reply 183 of 212, by Predator99
Thats easy and can be done by inserting...
SDL_SetWindowSize(window,640,480);
...without performance loss.
47.52 KiB
Reply 184 of 212, by Deksor
Not really, the quality isn't as great. This is the most crude way of doing it. Some lines are doubled, others aren't. On the other hand what I'm doing is less visible.
Reply 185 of 212, by Predator99
Deksor wrote on 2020-08-05, 12:46:
Yes dont think it makes a huge differences as this mode isnt looking perfect anyway.
Do you have your own device running in the mean time..?
Reply 186 of 212, by Deksor
I haven't tested it yet, I've been away for nearly two weeks 😁
I have to figure this out.
Reply 187 of 212, by Predator99
Some further improvements for 200 line modes. You can now switch filter on/off by pressing up/down keys. This works for 320x200 (filter should be on) and 640x200...think there are no more 200 line modes..?
Everything is displayed in a 640x400 window. Every line for unfiltered mode is doubled to fill the window. For 320x200 only a small portion is filled.
Hope root42 can manage to resize the window on the fly 😉
So when switching from unfiltered to filtred the previous unfiltered picture stays on screen as shown in 2nd + 3rd screenshot.
All still running at 16MHz sample rate and real time!
112.29 KiB
122.02 KiB
152.26 KiB
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#define SDL_MAIN_HANDLED
#include <C:\Program Files (x86)\mingw-w64\i686-8.1.0-posix-dwarf-rt_v6-rev0\mingw32\lib\SDL2-2.0.12\i686-w64-
mingw32\include\SDL2\SDL.h>
mingw32\include\SDL2\SDL_surface.h>
#include <io.h>
#include <fcntl.h>
#define IMG_WIDTH 640
#define IMG_HEIGHT 400
#if SDL_BYTEORDER == SDL_BIG_ENDIAN
static const Uint32 rmask = 0xff000000;
static const Uint32 gmask = 0x00ff0000;
static const Uint32 bmask = 0x0000ff00;
static const Uint32 amask = 0x000000ff;
#else
static const Uint32 rmask = 0x00ff0000;
static const Uint32 gmask = 0x0000ff00;
static const Uint32 bmask = 0x000000ff;
static const Uint32 amask = 0xff000000;
#endif
static Uint32 egapal[64];
void
init_pal()
int i;
for( i = 0; i < 64; ++i ) {
Uint32 color =
( ((i & (1 << 0)) << 1) + ((i & (1 << 3)) >> 3)) * (0x55555555 & bmask)
+ (((i & (1 << 1)) >> 0) + ((i & (1 << 3)) >> 3)) * (0x55555555 & gmask)
+ (((i & (1 << 2)) >> 1) + ((i & (1 << 3)) >> 3)) * (0x55555555 & rmask)
+ amask
printf("%xd ", color);
egapal[i] = color;
inline
void
pset(
SDL_Surface *surface,
Show last 708 lines
  unsigned int x,
unsigned int y,
unsigned char color
if( x >= IMG_WIDTH || y >= IMG_HEIGHT ) {
return;
Uint32 *target_pixel = surface->pixels + y * surface->pitch +
x * sizeof( *target_pixel );
*target_pixel = egapal[color];
int main()
_setmode (_fileno( stdin ), _O_BINARY );
int x_scaled;
int filter=0;
int mode=320;
int vsynccount=0;
int hsynccount=0;
int new_frame = 0;
unsigned char value, color1;
int hsync = 0, vsync = 0;
int frame = 0;
unsigned int vsyncc = 0, ref_len = 0;
unsigned int x = 0, y = 0;
SDL_Window *window;
init_pal();
SDL_Init(SDL_INIT_VIDEO);
window = SDL_CreateWindow(
"SIGROK2EGA",
SDL_WINDOWPOS_UNDEFINED,
IMG_WIDTH,
IMG_HEIGHT,
SDL_WINDOW_SHOWN|SDL_WINDOW_OPENGL|SDL_WINDOW_RESIZABLE
if (window == NULL) {
SDL_Log( "Could not create window: %s", SDL_GetError());
SDL_Quit();
return 1;
SDL_Renderer *ren = SDL_CreateRenderer(window, -1, SDL_RENDERER_ACCELERATED | SDL_RENDERER_PRESENTVSYNC);
if (ren == NULL) {
SDL_DestroyWindow( window );
SDL_Log( "SDL_CreateRenderer Error: %s", SDL_GetError());
SDL_Quit();
return 1;
SDL_Surface *surface =
SDL_CreateRGBSurface(
0,
IMG_WIDTH,
IMG_HEIGHT,
32,
rmask,
gmask,
bmask,
amask
if (surface == NULL) {
SDL_Log("SDL_CreateRGBSurface() failed: %s", SDL_GetError());
SDL_Quit();
return 1;
SDL_Texture *tex = SDL_CreateTextureFromSurface(ren, surface);
if( tex == NULL ) {
SDL_Log( "SDL_CreateTextueFromSurface() failed: %s", SDL_GetError());
SDL_Quit();
return 1;
//SDL_SetWindowSize(window,640,480);
//SDL_RenderSetLogicalSize(ren, 640, 400);
//SDL_RenderSetScale(ren, 2, 2);
while(!feof(stdin)) {
value = fgetc(stdin);
vsync = value & 128;
hsync = value & 64;
vsynccount=vsynccount+vsync;
//hsynccount=hsynccount+hsync;
if(mode==640){
if( vsync != 0 ) {
vsyncc = 0;
new_frame = 0;
} else {
vsyncc++;
if( vsyncc > 20 ) {
vsyncc = 0;
y = 0;
// this means a new frame?
if( !new_frame ) {
new_frame = 1;
frame++;
if (vsynccount <400000) {if (vsynccount > 380000) {mode=320;}}else {mode=640;}
printf(" vsynccount %u\n", vsynccount);
//printf(" hsynccount %u\n", hsynccount);
vsynccount=0;
//hsynccount=0;
SDL_UpdateTexture(tex, NULL, surface->pixels, surface->pitch);
// SDL_RenderClear(ren);
SDL_RenderCopy(ren, tex, NULL, NULL);
SDL_RenderPresent(ren);
SDL_Event e;
if (SDL_PollEvent(&e)) {
if (e.type == SDL_QUIT) {
break;
} else if( e.type == SDL_KEYDOWN ) {
switch( e.key.keysym.sym )
case SDLK_UP:
filter=1;
printf("Filter on\n");
break;
case SDLK_DOWN:
filter=0;
printf("Filter off\n");
break;
default:
break;
color1 = value & 0x3F;
int x_scaled=x-75 ;
int y_scaled = y-3 ;
//if (y>32){
//if (y<235){
pset(surface, x_scaled, y_scaled, color1);
x++;
if( hsync ) {
ref_len++;
if( ref_len > 30 && x > 700 ) {
// pset(surface, x_scaled, y, 5);
y++;
x = 0;
} else {
ref_len = 0;
if(mode==320){
if( vsync == 0 ) {
vsyncc = 0;
new_frame = 0;
} else {
vsyncc++;
if( vsyncc > 20 ) {
vsyncc = 0;
y = 0;
if( !new_frame ) {
new_frame = 1;
// frame++;
vsynccount=0;
//hsynccount=0;
SDL_Event e;
break;
case SDLK_UP:
filter=1;
break;
case SDLK_DOWN:
filter=0;
break;
default:
break;
//fast perfekt int x_scaled = round(319.5/714.5*(x-126));
//int x_scaled = round(319.5/714.5*(x-126));
//if (x==174) {int x_scaled = 300;}
// int x_scaled=x ;
int y_scaled = y - 34;
//unfiltered: data is from x=168 and 719 pixels long. Needs to be scaled to 640 pixels to fit in window
if (filter==0) {
x_scaled=x-168;
x_scaled=x_scaled*0.9;
pset(surface, x_scaled , y_scaled*2, color1);
pset(surface, x_scaled , (y_scaled*2)-1, color1);
else {
x_scaled=330;
//if (y>32){
if (y<235){
if (x<889) {
if (x<550) {
if (x>174) {
if (x<359) {
if (x<194) {
if (x>174) {
if (x== 175 ) {x_scaled=0 ;}
if (x== 177 ) {x_scaled=1 ;}
if (x== 179 ) {x_scaled=2 ;}
if (x== 182 ) {x_scaled=3 ;}
if (x== 184 ) {x_scaled=4 ;}
if (x== 186 ) {x_scaled=5 ;}
if (x== 188 ) {x_scaled=6 ;}
if (x== 191 ) {x_scaled=7 ;}
if (x== 193 ) {x_scaled=8 ;}
if (x<218) {
if (x>194) {
if (x== 195 ) {x_scaled=9 ;}
if (x== 197 ) {x_scaled=10 ;}
if (x== 200 ) {x_scaled=11 ;}
if (x== 202 ) {x_scaled=12 ;}
if (x== 204 ) {x_scaled=13 ;}
if (x== 206 ) {x_scaled=14 ;}
if (x== 209 ) {x_scaled=15 ;}
if (x== 211 ) {x_scaled=16 ;}
if (x== 213 ) {x_scaled=17 ;}
if (x== 215 ) {x_scaled=18 ;}
if (x== 217 ) {x_scaled=19 ;}
if (x>219) {
if (x<236) {
if (x== 220 ) {x_scaled=20 ;}
if (x== 222 ) {x_scaled=21 ;}
if (x== 224 ) {x_scaled=22 ;}
if (x== 226 ) {x_scaled=23 ;}
if (x== 229 ) {x_scaled=24 ;}
if (x== 231 ) {x_scaled=25 ;}
if (x== 233 ) {x_scaled=26 ;}
if (x== 235 ) {x_scaled=27 ;}
if (x>237) {
if (x<261) {
if (x== 238 ) {x_scaled=28 ;}
if (x== 240 ) {x_scaled=29 ;}
if (x== 242 ) {x_scaled=30 ;}
if (x== 244 ) {x_scaled=31 ;}
if (x== 247 ) {x_scaled=32 ;}
if (x== 249 ) {x_scaled=33 ;}
if (x== 251 ) {x_scaled=34 ;}
if (x== 253 ) {x_scaled=35 ;}
if (x== 255 ) {x_scaled=36 ;}
if (x== 258 ) {x_scaled=37 ;}
if (x== 260 ) {x_scaled=38 ;}
if (x<283) {
if (x>261) {
if (x== 262 ) {x_scaled=39 ;}
if (x== 264 ) {x_scaled=40 ;}
if (x== 267 ) {x_scaled=41 ;}
if (x== 269 ) {x_scaled=42 ;}
if (x== 271 ) {x_scaled=43 ;}
if (x== 273 ) {x_scaled=44 ;}
if (x== 276 ) {x_scaled=45 ;}
if (x== 278 ) {x_scaled=46 ;}
if (x== 280 ) {x_scaled=47 ;}
if (x== 282 ) {x_scaled=48 ;}
if (x<310) {
if (x>284) {
if (x== 285 ) {x_scaled=49 ;}
if (x== 287 ) {x_scaled=50 ;}
if (x== 289 ) {x_scaled=51 ;}
if (x== 291 ) {x_scaled=52 ;}
if (x== 293 ) {x_scaled=53 ;}
if (x== 296 ) {x_scaled=54 ;}
if (x== 298 ) {x_scaled=55 ;}
if (x== 300 ) {x_scaled=56 ;}
if (x== 302 ) {x_scaled=57 ;}
if (x== 305 ) {x_scaled=58 ;}
if (x== 307 ) {x_scaled=59 ;}
if (x== 309 ) {x_scaled=60 ;}
if (x>310) {
if (x<332) {
if (x== 311 ) {x_scaled=61 ;}
if (x== 314 ) {x_scaled=62 ;}
if (x== 316 ) {x_scaled=63 ;}
if (x== 318 ) {x_scaled=64 ;}
if (x== 320 ) {x_scaled=65 ;}
if (x== 323 ) {x_scaled=66 ;}
if (x== 325 ) {x_scaled=67 ;}
if (x== 327 ) {x_scaled=68 ;}
if (x== 329 ) {x_scaled=69 ;}
if (x== 331 ) {x_scaled=70 ;}
if (x>333) {
if (x<359) {
if (x== 334 ) {x_scaled=71 ;}
if (x== 336 ) {x_scaled=72 ;}
if (x== 338 ) {x_scaled=73 ;}
if (x== 340 ) {x_scaled=74 ;}
if (x== 343 ) {x_scaled=75 ;}
if (x== 345 ) {x_scaled=76 ;}
if (x== 347 ) {x_scaled=77 ;}
if (x== 349 ) {x_scaled=78 ;}
if (x== 352 ) {x_scaled=79 ;}
if (x== 354 ) {x_scaled=80 ;}
if (x== 356 ) {x_scaled=81 ;}
if (x== 358 ) {x_scaled=82 ;}
}}} else {
if (x>360) {
if (x<400) {
if (x== 361 ) {x_scaled=83 ;}
if (x== 363 ) {x_scaled=84 ;}
if (x== 365 ) {x_scaled=85 ;}
if (x== 367 ) {x_scaled=86 ;}
if (x== 369 ) {x_scaled=87 ;}
if (x== 372 ) {x_scaled=88 ;}
if (x== 374 ) {x_scaled=89 ;}
if (x== 376 ) {x_scaled=90 ;}
if (x== 378 ) {x_scaled=91 ;}
if (x== 381 ) {x_scaled=92 ;}
if (x== 383 ) {x_scaled=93 ;}
if (x== 385 ) {x_scaled=94 ;}
if (x== 387 ) {x_scaled=95 ;}
if (x== 390 ) {x_scaled=96 ;}
if (x== 392 ) {x_scaled=97 ;}
if (x== 394 ) {x_scaled=98 ;}
if (x== 396 ) {x_scaled=99 ;}
if (x== 399 ) {x_scaled=100 ;}
if (x>400) {
if (x<422) {
if (x== 401 ) {x_scaled=101 ;}
if (x== 403 ) {x_scaled=102 ;}
if (x== 405 ) {x_scaled=103 ;}
if (x== 407 ) {x_scaled=104 ;}
if (x== 410 ) {x_scaled=105 ;}
if (x== 412 ) {x_scaled=106 ;}
if (x== 414 ) {x_scaled=107 ;}
if (x== 416 ) {x_scaled=108 ;}
if (x== 419 ) {x_scaled=109 ;}
if (x== 421 ) {x_scaled=110 ;}
if (x>422) {
if (x<449) {
if (x== 423 ) {x_scaled=111 ;}
if (x== 425 ) {x_scaled=112 ;}
if (x== 428 ) {x_scaled=113 ;}
if (x== 430 ) {x_scaled=114 ;}
if (x== 432 ) {x_scaled=115 ;}
if (x== 434 ) {x_scaled=116 ;}
if (x== 437 ) {x_scaled=117 ;}
if (x== 439 ) {x_scaled=118 ;}
if (x== 441 ) {x_scaled=119 ;}
if (x== 443 ) {x_scaled=120 ;}
if (x== 445 ) {x_scaled=121 ;}
if (x== 448 ) {x_scaled=122 ;}
if (x<549){
if (x>449) {
if (x<471) {
if (x== 450 ) {x_scaled=123 ;}
if (x== 452 ) {x_scaled=124 ;}
if (x== 454 ) {x_scaled=125 ;}
if (x== 457 ) {x_scaled=126 ;}
if (x== 459 ) {x_scaled=127 ;}
if (x== 461 ) {x_scaled=128 ;}
if (x== 463 ) {x_scaled=129 ;}
if (x== 466 ) {x_scaled=130 ;}
if (x== 468 ) {x_scaled=131 ;}
if (x== 470 ) {x_scaled=132 ;}
if (x>471) {
if (x<500) {
if (x== 472 ) {x_scaled=133 ;}
if (x== 475 ) {x_scaled=134 ;}
if (x== 477 ) {x_scaled=135 ;}
if (x== 479 ) {x_scaled=136 ;}
if (x== 481 ) {x_scaled=137 ;}
if (x== 483 ) {x_scaled=138 ;}
if (x== 486 ) {x_scaled=139 ;}
if (x== 488 ) {x_scaled=140 ;}
if (x== 490 ) {x_scaled=141 ;}
if (x== 492 ) {x_scaled=142 ;}
if (x== 495 ) {x_scaled=143 ;}
if (x== 497 ) {x_scaled=144 ;}
if (x== 499 ) {x_scaled=145 ;}
if (x>500) {
if (x<522) {
if (x== 501 ) {x_scaled=146 ;}
if (x== 504 ) {x_scaled=147 ;}
if (x== 506 ) {x_scaled=148 ;}
if (x== 508 ) {x_scaled=149 ;}
if (x== 510 ) {x_scaled=150 ;}
if (x== 513 ) {x_scaled=151 ;}
if (x== 515 ) {x_scaled=152 ;}
if (x== 517 ) {x_scaled=153 ;}
if (x== 519 ) {x_scaled=154 ;}
if (x== 521 ) {x_scaled=155 ;}
if (x>523) {
if (x<550) {
if (x== 524 ) {x_scaled=156 ;}
if (x== 526 ) {x_scaled=157 ;}
if (x== 528 ) {x_scaled=158 ;}
if (x== 530 ) {x_scaled=159 ;}
if (x== 533 ) {x_scaled=160 ;}
if (x== 535 ) {x_scaled=161 ;}
if (x== 537 ) {x_scaled=162 ;}
if (x== 539 ) {x_scaled=163 ;}
if (x== 542 ) {x_scaled=164 ;}
if (x== 544 ) {x_scaled=165 ;}
if (x== 546 ) {x_scaled=166 ;}
if (x== 548 ) {x_scaled=167 ;}
}}} }}} else {
if (x<750){
if (x<674){
if (x>550) {
if (x<572) {
if (x== 551 ) {x_scaled=168 ;}
if (x== 553 ) {x_scaled=169 ;}
if (x== 555 ) {x_scaled=170 ;}
if (x== 557 ) {x_scaled=171 ;}
if (x== 559 ) {x_scaled=172 ;}
if (x== 562 ) {x_scaled=173 ;}
if (x== 564 ) {x_scaled=174 ;}
if (x== 566 ) {x_scaled=175 ;}
if (x== 568 ) {x_scaled=176 ;}
if (x== 571 ) {x_scaled=177 ;}
if (x>572) {
if (x<598) {
if (x== 573 ) {x_scaled=178 ;}
if (x== 575 ) {x_scaled=179 ;}
if (x== 577 ) {x_scaled=180 ;}
if (x== 580 ) {x_scaled=181 ;}
if (x== 582 ) {x_scaled=182 ;}
if (x== 584 ) {x_scaled=183 ;}
if (x== 586 ) {x_scaled=184 ;}
if (x== 589 ) {x_scaled=185 ;}
if (x== 591 ) {x_scaled=186 ;}
if (x== 593 ) {x_scaled=187 ;}
if (x== 595 ) {x_scaled=188 ;}
if (x== 597 ) {x_scaled=189 ;}
if (x>599) {
if (x<623) {
if (x== 600 ) {x_scaled=190 ;}
if (x== 602 ) {x_scaled=191 ;}
if (x== 604 ) {x_scaled=192 ;}
if (x== 606 ) {x_scaled=193 ;}
if (x== 609 ) {x_scaled=194 ;}
if (x== 611 ) {x_scaled=195 ;}
if (x== 613 ) {x_scaled=196 ;}
if (x== 615 ) {x_scaled=197 ;}
if (x== 618 ) {x_scaled=198 ;}
if (x== 620 ) {x_scaled=199 ;}
if (x== 622 ) {x_scaled=200 ;}
if (x>623) {
if (x<650) {
if (x== 624 ) {x_scaled=201 ;}
if (x== 627 ) {x_scaled=202 ;}
if (x== 629 ) {x_scaled=203 ;}
if (x== 631 ) {x_scaled=204 ;}
if (x== 633 ) {x_scaled=205 ;}
if (x== 635 ) {x_scaled=206 ;}
if (x== 638 ) {x_scaled=207 ;}
if (x== 640 ) {x_scaled=208 ;}
if (x== 642 ) {x_scaled=209 ;}
if (x== 644 ) {x_scaled=210 ;}
if (x== 647 ) {x_scaled=211 ;}
if (x== 649 ) {x_scaled=212 ;}
if (x>650) {
if (x<674) {
if (x== 651 ) {x_scaled=213 ;}
if (x== 653 ) {x_scaled=214 ;}
if (x== 656 ) {x_scaled=215 ;}
if (x== 658 ) {x_scaled=216 ;}
if (x== 660 ) {x_scaled=217 ;}
if (x== 663 ) {x_scaled=218 ;}
if (x== 665 ) {x_scaled=219 ;}
if (x== 667 ) {x_scaled=220 ;}
if (x== 669 ) {x_scaled=221 ;}
if (x== 671 ) {x_scaled=222 ;}
if (x== 673 ) {x_scaled=223 ;}
if (x>675) {
if (x<699) {
if (x== 676 ) {x_scaled=224 ;}
if (x== 678 ) {x_scaled=225 ;}
if (x== 680 ) {x_scaled=226 ;}
if (x== 682 ) {x_scaled=227 ;}
if (x== 685 ) {x_scaled=228 ;}
if (x== 687 ) {x_scaled=229 ;}
if (x== 689 ) {x_scaled=230 ;}
if (x== 691 ) {x_scaled=231 ;}
if (x== 694 ) {x_scaled=232 ;}
if (x== 696 ) {x_scaled=233 ;}
if (x== 698 ) {x_scaled=234 ;}
if (x>699) {
if (x<724) {
if (x== 700 ) {x_scaled=235 ;}
if (x== 703 ) {x_scaled=236 ;}
if (x== 705 ) {x_scaled=237 ;}
if (x== 707 ) {x_scaled=238 ;}
if (x== 709 ) {x_scaled=239 ;}
if (x== 711 ) {x_scaled=240 ;}
if (x== 714 ) {x_scaled=241 ;}
if (x== 716 ) {x_scaled=242 ;}
if (x== 718 ) {x_scaled=243 ;}
if (x== 720 ) {x_scaled=244 ;}
if (x== 723 ) {x_scaled=245 ;}
if (x>724) {
if (x<750) {
if (x== 725 ) {x_scaled=246 ;}
if (x== 727 ) {x_scaled=247 ;}
if (x== 729 ) {x_scaled=248 ;}
if (x== 732 ) {x_scaled=249 ;}
if (x== 734 ) {x_scaled=250 ;}
if (x== 736 ) {x_scaled=251 ;}
if (x== 738 ) {x_scaled=252 ;}
if (x== 741 ) {x_scaled=253 ;}
if (x== 743 ) {x_scaled=254 ;}
if (x== 745 ) {x_scaled=255 ;}
if (x== 747 ) {x_scaled=256 ;}
if (x== 749 ) {x_scaled=257 ;}
}}} else {
if (x>751) {
if (x<775) {
if (x== 752 ) {x_scaled=258 ;}
if (x== 754 ) {x_scaled=259 ;}
if (x== 756 ) {x_scaled=260 ;}
if (x== 758 ) {x_scaled=261 ;}
if (x== 761 ) {x_scaled=262 ;}
if (x== 763 ) {x_scaled=263 ;}
if (x== 765 ) {x_scaled=264 ;}
if (x== 767 ) {x_scaled=265 ;}
if (x== 770 ) {x_scaled=266 ;}
if (x== 772 ) {x_scaled=267 ;}
if (x== 774 ) {x_scaled=268 ;}
if (x>775) {
if (x>775) {
if (x<800) {
if (x== 776 ) {x_scaled=269 ;}
if (x== 778 ) {x_scaled=270 ;}
if (x== 781 ) {x_scaled=271 ;}
if (x== 783 ) {x_scaled=272 ;}
if (x== 785 ) {x_scaled=273 ;}
if (x== 787 ) {x_scaled=274 ;}
if (x== 790 ) {x_scaled=275 ;}
if (x== 792 ) {x_scaled=276 ;}
if (x== 794 ) {x_scaled=277 ;}
if (x== 796 ) {x_scaled=278 ;}
if (x== 799 ) {x_scaled=279 ;}
if (x>800) {
if (x<822) {
if (x== 801 ) {x_scaled=280 ;}
if (x== 803 ) {x_scaled=281 ;}
if (x== 805 ) {x_scaled=282 ;}
if (x== 808 ) {x_scaled=283 ;}
if (x== 810 ) {x_scaled=284 ;}
if (x== 812 ) {x_scaled=285 ;}
if (x== 814 ) {x_scaled=286 ;}
if (x== 817 ) {x_scaled=287 ;}
if (x== 819 ) {x_scaled=288 ;}
if (x== 821 ) {x_scaled=289 ;}
if (x>822) {
if (x<849) {
if (x== 823 ) {x_scaled=290 ;}
if (x== 825 ) {x_scaled=291 ;}
if (x== 828 ) {x_scaled=292 ;}
if (x== 830 ) {x_scaled=293 ;}
if (x== 832 ) {x_scaled=294 ;}
if (x== 834 ) {x_scaled=295 ;}
if (x== 837 ) {x_scaled=296 ;}
if (x== 839 ) {x_scaled=297 ;}
if (x== 841 ) {x_scaled=298 ;}
if (x== 843 ) {x_scaled=299 ;}
if (x== 846 ) {x_scaled=300 ;}
if (x== 848 ) {x_scaled=301 ;}
if (x>849) {
if (x<864) {
if (x== 850 ) {x_scaled=302 ;}
if (x== 852 ) {x_scaled=303 ;}
if (x== 854 ) {x_scaled=304 ;}
if (x== 857 ) {x_scaled=305 ;}
if (x== 859 ) {x_scaled=306 ;}
if (x== 861 ) {x_scaled=307 ;}
if (x== 863 ) {x_scaled=308 ;}
if (x>865) {
if (x<889) {
if (x== 866 ) {x_scaled=309 ;}
if (x== 868 ) {x_scaled=310 ;}
if (x== 870 ) {x_scaled=311 ;}
if (x== 872 ) {x_scaled=312 ;}
if (x== 875 ) {x_scaled=313 ;}
if (x== 877 ) {x_scaled=314 ;}
if (x== 879 ) {x_scaled=315 ;}
if (x== 881 ) {x_scaled=316 ;}
if (x== 884 ) {x_scaled=317 ;}
if (x== 886 ) {x_scaled=318 ;}
if (x== 888 ) {x_scaled=319 ;}
pset(surface, x_scaled , y_scaled, color1);
x++;
if( hsync ) {
ref_len++;
y++;
x = 0;
} else {
ref_len = 0;
SDL_Quit();
return 0;
Reply 188 of 212, by Predator99
So I was very short before replacing my 4790 with a 4790k CPU to get the additional power to run it with 24 MHz in real-time under Windows.
But then I decided to give Linux a try and installed SuSE.
It runs and it is fassssstttttt...much faster than Windows! It runs at 24MHz without problem and looks GREAT! Perfect picture at 320x200. CPU utilization is about 80%.
The jitter at 640x350 is still there but you dont really notice it (at least in the unscaled window) as the refresh is very fast. I would say it looks nice as you see the screen refreshing and you know something is going on 😉 For me there is no need to invest much work to remove it...
Somebody else tested this in the mean time..?
This is a great and useful project, thanks again root42 for your work!!! 😀
Reply 191 of 212, by matze79
Predator99 wrote on 2020-08-27, 11:12:
You can get more, if recompiling the whole System with optimisations for your CPU.
I use Linux for all daily tasks.
Windows 10 is ugly as hell, i never disliked any windows so much.
I want my CPU Power for doing my Stuff, not for running useless "Microsoft bloat threads".
Great it runs so good now, hehe maybe i also get a analyzer.
Reply 192 of 212, by Predator99
root42 wrote on 2020-08-04, 11:01:
Predator99 wrote on 2020-08-04, 10:02:
Thanks..all based on your nice work..! […]
Unfortunately I have no idea how git works.... 😉
Do you know how I can resize the window from 640x350 to 320x200 without closing it? I tried
SDL_SetWindowSize(window,320,200);
...but this also scales the content down.
Also played with
SDL_RenderSetLogicalSize(ren, 320,200);
SDL_RenderSetScale(ren, 1,1);
...without success.
We probably want to create a second texture for that and set that as the render surface. When I am back from vacation I will have a look.
YES...! I found a solution for this problem:
Instead of
We do...:
SDL_RenderCopyEx(ren,tex,&srcrect,&dstrect, 0, NULL, SDL_FLIP_NONE);
...and can use one window and scale every picture size in it and also adjust the aspect ratio.
Therefore we can fill a 640x400 window with a 320x200 picture. Currently not at home and cannot test the speed but it seems to be equal.
Reply 193 of 212, by Predator99
matze79 wrote on 2020-08-29, 10:06:
You can get more, if recompiling the whole System with optimisations for your CPU. I use Linux for all daily tasks. Windows 10 i […]
Yes, I also sticked to Win7. I have Win10 on my company laptop and I dont like it.
I like linux and have been using it since the 90s but I become to lazy, Win is more convenient...
Reply 194 of 212, by Benedikt
Making sure that the program itself is optimized for your CPU is fully sufficient in a case like this.
Maybe recompile SDL, as well, but even that should be almost irrelevant.
Reply 195 of 212, by Predator99
Made some major improvements and created a youtube-account 😉
- as written above, window is now filled in all modes
- filter can be turned on and of with key-up and key-down
- window size can be changed with key-left and key-right
- info is shown in title bar
The video also demonstrates the 320x200 filtering, see title bar.
I need to improve my video recording, does not look as good as it should. Will next record a fullscreen capture, hope this has a better quality...
https://youtu.be/iKRNfpY_To4
https://youtu.be/1IiOOC7cG7E
(screen recording software crashed in between, but not sigrok2ega 😀
Reply 196 of 212, by root42
Nice result! One thing: the brown is wrong. Very visible in SQ3. 😀 IIRC IBM didn't interpret the dark yellow as dark yellow but rather used a brown hue instead.
YouTube and Bonus
Reply 197 of 212, by Predator99
Thank you!
I remember I to have read this somewhere but I dont notice it... 😉
Still not happy with the Youtube Quality. Think I have to record a larger screen size to get better quality but with this the recorde doesnt keep up.
At least on my screen it looks perfect, no video error at all...!
2 more:
https://www.youtube.com/watch?v=9Jyn1USuu98
https://www.youtube.com/watch?v=EnF-w2OUmQU
Reply 198 of 212, by root42
You can use some software to re-encode your capture as 4k and upload that to YT. It will force YT to use higher bitrates and resolution, leading to better visual quality. Even if your original material wasn't 4k to begin with.
YouTube and Bonus
