CF IDE adapter problems
First post, by Arbuthnot
I'm trying to get Windows 3.11 up and running on my 486. With an old IDE disk it seems to be fine but I got a CF - IDE adapter and all seemed OK through installing DOS but I'm having endless hassle now. It got through the install once then kept crashing, I wiped it and started again and get "general protection faults" in winsetup. I've tried a different CF card. Does it sound like just a duff device?
Reply 1 of 19, by ElBrunzy
Over time I made a collection of CF2IDE adapters, CF cards and IDE PCI cards. I ran into the problem you describe many times and it can be a real puzzle to find a working combination for a specific machine. If your 486 board has PCI, an IDE PCI adaptor is quite cheap and is often more verbose than BIOS to diagnose problem, also they would help you support larger capacity. Things you can try now is different DMA and PIO mode in your BIOS, try 40 or 80 wires IDE cables. What are your CF cards make and model ?
Reply 2 of 19, by kalohimal
CF cards are not created equal, some do not implement the full sets of IDE protocol. For example, some implements the 16-bit IDE interface but not the 8-bit interface. Couple with half baked BIOS and you can run into problems. When one CF doesn't work, I would try another with different brand and capacity. The CF to IDE adapter is just simple straight connections of the pins without any IC in between (as oppose to SD to IDE adapter which has a chip to convert the protocol).
Slow down your CPU with CPUSPD for DOS retro gaming.
Reply 3 of 19, by Arbuthnot
ElBrunzy wrote on 2020-08-06, 02:58:
I have one old "Cisco" flash card from my networking days and one brand-new "Sandisk"; both are being equally temperamental. I've also got one of these "Transcend" ones but I've not tried that yet. No IDE I'm afraid so that's not an option. The BIOS also has no options for DMA etc.
Reply 4 of 19, by Arbuthnot
kalohimal wrote on 2020-08-06, 06:02:
I've tried 2 brands, but I take your point - I've been bitten by cheap USB flash in the past and I always avoid it now. I managed to get everything installed from scratch again last night but I get random "exception in kernel" type errors that force a reboot. The old 400MB IDE disk seems to work OK so I don't think it's the PC.
Reply 5 of 19, by Jo22
=Maybe it is related to FastDisk/32BDA?
If it accidentally finds your HDD to be compatible, weird things can happen:
http://www.os2museum.com/wp/how-to-please-wdctrl/
To enable/disable, open system.ini.
Look for [386 enh] block and add (unless available) :
32BitDiskAccess =
This will make the option available in Control Panel (386 Enhanced applet).
32BitDiskAccess = true
32BitDiskAccess = false
More info:
http://stephan.win31.de/w31mm_en.htm#32-Bit-Platte
https://en.wikipedia.org/wiki/32-bit_disk_access
Reply 6 of 19, by p6889k
On my 386DX I'm successfully using this:
CF adapter: Syba IDE/PATA to CF Adapter
https://www.amazon.com/gp/product/B001JTO782/ … 0?ie=UTF8&psc=1
CF Card: Transcend 8GB CompactFlash Memory Card 133x (TS8GCF133)
https://www.amazon.com/gp/product/B000W05O5O/ … e?ie=UTF8&psc=1
I only use 512MB as that is all that the board can see.
I also tried various SanDisk cards and they didn't work.
I was also disappointed that Transcend TS512MCF200I 512MB Industrial Card also didn't work, it was giving me all sorts of write errors, even though it works just fine on newer HW:
https://www.amazon.com/gp/product/B004I66880/ … e?ie=UTF8&psc=1
Sinclair ZX Spectrum 48k, 48k+, 128k, +2
Amiga 1200, 68030/40mhz
386DX/33, ET4000, SBPro2, MT32
Dual PPro/200, Millennium II, Voodoo 2, AWE32, SC-55
etc.
Reply 7 of 19, by Arbuthnot
Jo22 wrote on 2020-08-06, 12:25:
=Maybe it is related to FastDisk/32BDA? If it accidentally finds your HDD to be compatible, weird things can happen: […]
32BitDiskAccess =
More info:
I'll try that later, thanks!
Reply 8 of 19, by Arbuthnot
p6889k wrote on 2020-08-06, 13:00:
On my 386DX I'm successfully using this: […]
Thanks mate, I'll check the model.
Reply 11 of 19, by SodaSuccubus
Don't cheap out with CF cards.
Iv had TERRIBLE luck trying to get those cheep transcend/generic brand CF cards working. Lots of errors reading the C drive, file corruption and other oddities.
Get something from a big name brand like SanDisk and you should be fine. Iv used a 16gb SanDisk Extreme for years without issue ever since.
Same with the CF Adapter. Give the one from Startech a try. They're generally regarded as a trusted company.
Reply 12 of 19, by Jo22
Arbuthnot wrote on 2020-08-06, 13:14:
32BitDiskAccess =
More info:
You're welcome. 🙂
Please also keep in mind that older versions (pre-WfW 3.11, like Win 3.1) can also run in Standard-Mode (via Win /S or Win /2)..
It's by no means ideal for a 486, but it almost always works.
Reply 13 of 19, by Arbuthnot
SodaSuccubus wrote on 2020-08-06, 13:53:
Don't cheap out with CF cards. […]
It's a Sandisk that I'm having problems with at the minute (that and the Cisco one before it). The larger Transcend card is put aside for my Linux on 486 project. It is a generic reader from eBay though.
Reply 14 of 19, by Arbuthnot
deksar wrote on 2020-08-06, 13:32:
Tried to set the CF to "true-ide" mode? Read this: https://ozgur.kazancci.com/down/set-compact-f … d%20disk%29.txt
The file ATCFWCHG.COM is here: https://ozgur.kazancci.com/down/
That utility returns "error #7" when I try it, and I found a forum thread from 2006 (!) with people having the same problem, saying that SanDisk no longer support that. So I guess that's out... thanks anyway, worth a shot!
Reply 15 of 19, by Arbuthnot
32BitDiskAccess =
More info:
That mode was already disabled by default so I guess that's not it, worth trying though.
Reply 16 of 19, by Jo22
Ok, was just an idea, after all. 😅
If the original driver doesn't work (it's ancient), then you could also try the MicroHouse driver (works with any HDD brand) or any other third party driver.
They usually support HDDs up to 8GB..
http://win31.de/edrivers.htm
Anyway, that's just another idea/workaround.
Hope you find the culprit.
Reply 17 of 19, by GigAHerZ
I have always used the cheapest ebay CF cards i can get my hands on and had no problems with any of those cards... never...
Reply 18 of 19, by Arbuthnot
Jo22 wrote on 2020-08-06, 20:24:
Ok, was just an idea, after all. :sweatdrop: If the original driver doesn't work (it's ancient), then you could also try the Mic […]
So I dug out a 128MB "disk-on-module" from an old CAD machine and tried that. DOS installs fine, but when I was installing Windows I hit a few problems. First time it crashed out trying to create virtual memory; I've got 64MB RAM so probably don't need that so I disabled it and got the installation to complete. Trying to install some Windows programs caused another crash, but just clicking about in the desktop seemed quite stable. Dropped back to DOS and installed Heretic and had an hour on that, no problem - so it really seems to be Windows that is playing up! I've tried 2 versions of 3.11 from REMOVEDbut I don't believe there's anything wrong with them. Guess I'll try the old 400 MB HDD again.
Reply 19 of 19, by Arbuthnot
GigAHerZ wrote on 2020-08-07, 08:12:
Maybe I'll try it with Win 95 to try and rule out the adapter / cards. DOS seems OK, it really is just 3.11 that's playing up.
