Reply 400 of 505, by TubeTimeUS
appiah4 wrote on 2020-07-10, 21:19:
There is certainly +5V and -12V elsewhere on the card, I can measure them on Pin 4 and Pin 11 of U11, for example. However, there is still no +5V on Pin 14 of U12. There is +5V on the +5V side of R38, but the side that is connected to Pin14 shows no voltage, it is shorted. When I remove the DAC at U12, I can measure +5V at Pin 14 of the socket.
Could be pins 14 and 15 got shorted somehow, you could measure continuity of the socket. Take out the DAC and measure the resistance between pin 14 and pin 15 on the IC as well, and between pin 14 and pin 2. If the chip has a short then it's bad. If the chip was ever installed backwards, it's bad.
You might also have a power supply that is going bad. Check the capacitors for evidence of leaking electrolyte, and measure the ripple voltage on each supply voltage rail. You can do this with a multimeter set to AC volts.
Also check your Snark Barker for any electrolytic capacitors that are in the wrong way around. If there are any that were in backwards, they need to be discarded and replaced.
Reply 401 of 505, by appiah4
TubeTimeUS wrote on 2020-07-16, 17:21:
Could be pins 14 and 15 got shorted somehow, you could measure continuity of the socket. Take out the DAC and measure the resist […]
Thanks TubeTimeUS. I have checked and all electrolytics are correctly oriented. The DAC was inserted the wrong way once before though, no wonder ir t is apparently bad now..
Anyway, I ordered replacements for the DAC, Amplifier and bus transceiver from a third supplier and they came in today. Replaced them all.
Also managed to find some 270pf/63V ceramic caps and replaced the 270pf/1kV ones I had on C68/C65 (which I kind of suspect are the cause here: prpbably low capacitance at 50V...). I will check and report tonight.
Reply 402 of 505, by Cyrix200+
appiah4 wrote on 2020-07-20, 18:37:
Thanks TubeTimeUS. I have checked and all electrolytics are correctly oriented. The DAC was inserted the wrong way once before t […]
Man, I hope that this fixes the final problems so you can enjoy the card 😀
1982 to 2001
Reply 403 of 505, by appiah4
After replacing the caps and the ICs, the behaviour is still the same: Distorted digital audio and no +5V on the new DAC chip's Pin 14. Pin 14 has continuity to R38, there is +5V voltage between one side of R38 and Ground and there is 0V between the side that is connected to the DAC and Ground. When I measure R38 to check its resistance I get 2.7K Ohms. Pin 14 is not shorted to Pin 2 on the DAC. Pin 14 is somehow NOT getting voltage, though. How come? I'm so confused..
Also, in case this helps, another strange behaviour I noticed is when I run Duke3D, sound effects can get 'stuck', i.e. keep repeating until a new sound effect comes along (the plane's passing by sound loops until I blow up the fuel tanks, etc.)
I'm starting to think maybe the DSP is bad at this point? But that doesn't explain missing +5V Vref on the DAC.. *SIGH*
Reply 404 of 505, by TubeTimeUS
Today I released SBDIAG (https://github.com/schlae/snark-barker/tree/master/sbdiag) which is a diagnostic utility for Snark Barkers and Sound Blasters. It makes no assumptions about a working card and can help with hardware-based troubleshooting for folks who have logic probes, oscilloscopes, or logic analyzers.
Thought maybe some of you could use it for troubleshooting cranky Snark Barkers.
Reply 405 of 505, by appiah4
Much appreciated thank you. I will give fixing my card another go in a few weeks, this should come in extremely handy!
Reply 406 of 505, by root42
One thing I am wondering: was the firmware of the original SB 1.0, 1.5 or 2.0 ever dumped? I would love to swap those out with the SnarkBarker firmware. I have one CT1351 chip here, in PLCC packaging, but couldn't dump its contents. I guess it is protected?
YouTube and Bonus
Reply 407 of 505, by Jo22
root42 wrote on 2020-09-01, 09:25:
I'm not sure if this answers your question, but I've got a very old non name SB clone that looks and acts like a SB 1.5 or 2.0..
Unfortunatelly, I'm unable to dump the contents of the microcontroller, because both the G540 and the TL866 that I've got are too primitve to support
8051, 8042 and similar oldschool microcontrollers. For this, I would need some Galep or similar professional programmer, I'm afraid. 🙁
Reply 408 of 505, by root42
I have a Galep 3. I tried reading the CT1351 with it, but it returns only FF. I may have chosen the wrong Intel MCU though. Or it is read protected.
YouTube and Bonus
Reply 409 of 505, by appiah4
root42 wrote on 2020-09-01, 11:51:
Didn't TubeTime have a huge blog post about how he encountered this same issue and went about solving it, which included resorting to an X-Ray microscope or something?
Reply 410 of 505, by root42
I dunno. Maybe? However his firmware is from a SB clone. So I figured he never succeeded.
YouTube and Bonus
Reply 411 of 505, by Tiido
The original MCUs are all protected. Some microsurgery would be needed to defeat the protection from what I know, chip gets decapped and protection mechanism gets disabled with laser or such.
Reply 412 of 505, by root42
Darn. Would have been too nice to have a dump 😀 I guess no one ever tried that? Or Creative probably had the images taken down pretty quickly...
YouTube and Bonus
Reply 416 of 505, by appiah4
Yeah it's a hillarious read.
I'm so salty that I still haven't resolved my card's PCM issue 🙁
Short of trying a second MCU I basically replaced every other component on the PCM circuitry.
What kind of programmer do I need to program the Atmel? Maybe I should try reflashing it..
That, or one of the sockets I used is faulty in a way I can't tell (I checked every chip leg to the solder point of the socket..), or one of the passives or the board are bad somehow, since they are all correct values..
I tried out the diagnostic utility but without a probe or oscilloscope I didn't get very far. I'm at the point I'd be OK with just mailing it out to whoever would want to try their hand at fixing it..
Reply 418 of 505, by appiah4
Yeah it's a 89S51.. I will look into the arduino way. Any other programmers you can recommend?
Reply 419 of 505, by Tronix
In 2019 TubeTime say in his twitter :
today i was able to confirm that i have a bit-accurate dump of the Sound Blaster CT-1351V202 DSP 2.02 firmware!
https://github.com/Tronix286/
