Where can I find "AMIBCP" (for DOS) ?
Reply 20 of 95, by debs3759
I have just emailed Herbert Oppman (the authority on NexGen systems) to see whether he still has the versions in the first post. If he does, I will post them here and add them to the VOGONS Driver Library
Reply 21 of 95, by debs3759
n0m4d wrote on 2019-08-30, 21:14:
i have only this one
If that can edit Pentium or P2/P3 era BIOS, I would love a copy please.
Reply 22 of 95, by nzoomed
I found a download for version 7.5 and 7.6 last night.
Dunno if it will work on an old 386 BIOS though.
http://www.aionsolution.com/it-support/others/bios-editor/
Some links are broken, but thanks to archive.org it can be downloaded here 😀
https://web.archive.org/web/20070106085807/ht … /tool_8_RC1.rar
Feiopa, are you still around? Im keen to grab what ever versions you have so I can try them out 😀
Im not sure if you have the above versions, but these links provide version 3.3 and 7.6
I got version 7.5 from another site, need to go to my history and grab it, but I can share it here if required.
Reply 23 of 95, by cyclone3d
Since this thread was started, I have a whole bunch of different BIOS modding tools. One included in one of the packs is mybcp ... folder structure makes it look like it was made by Herbert Oppmann. Source code is there and everything:
Herbert_Oppmann--mybcp.zip
286.59 KiB
359 downloads
I'm looking for some more stuff right now and also running a .zip password cracker on some 20MB file I downloaded quite a while ago. No clue what is in it or how long it will take to crack.
Here is an ftp that looks like it has a lot of what I have, including the above:
ftp://ftp.kazachya.net/Pub/--=%20%7B%20TREIBE … /Bios/!Flasher/
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 24 of 95, by Anonymous Coward
I believe AMI was contacted about purchasing old copies of AMIBCP at least once. I can't remember the exact answer, but it was either negative or no reply. I guess it wouldn't hurt to try again. Does anyone have contacts at AMI?
I checked out the contents of Hebert Oppmann mybcp.zip. IT has two folders, BCP94 and MYBCP. Neither folder contains any text files. I presume BCP94 works with AMI BIOSes from 1994, and MYBCP is a mystery. What we really need is something that works on BIOSes from 1990-1993, but I am sceptical either or these programs will do the job. I think we already have a copy of AMIBCP from 1994 and it's not backward compatible.
Just for the record, I tried both of these executables with AMIBIOS ROMs from 1990 and 1991, neither could be read with an error message stating the ROM image is not 128kb. I suspect this tool can only open WinBIOS ROM images 128kb in length.
Reply 25 of 95, by Anonymous Coward
feipoa wrote on 2019-08-31, 04:10:
It would be nice to get a hold of every version between 1.0 and 5.0, but I'm feeling pretty pessimistic about this. The odds are about as good as finding a MR BIOS image for the VLSI topcat.
That was found. So maybe there is some hope afterall!
Reply 26 of 95, by nzoomed
Anonymous Coward wrote on 2020-08-11, 00:03:
I reckon it comes down to speaking to the right person at the company.
Perhaps some youtuber in the community such as David Murray or LGR might have better luck if they were able to interview someone from the company or someone who even used to work there who coded these ROMs to begin with.
Supposedly version 7.5 for DOS can edit roms from the early 90s, so I will check on my BIOS later today.
Reply 27 of 95, by Anonymous Coward
nzoomed wrote on 2020-08-11, 01:22:
Who told you that?
Reply 28 of 95, by nzoomed
Anonymous Coward wrote on 2020-08-11, 01:43:
Who told you that?
Was reading comments on a forum, but I question that its accurate, but all I know is it will only run on DOS.
From what I can tell, the version numbers for DOS are different than the windows versions. Some forums are listing windows versions 2.x that do newer BIOS than 7.x versions that only run on DOS and support older ROMs
Looking on old forum posts dsted around 2005, version 2.4x appears to have been a new release at the time, yet my version 7.5 is older
Reply 29 of 95, by Anonymous Coward
Correct. DOS version numbers do not correlate with Windows version numbers.
I highly doubt v7.5 for DOS will read v1.x and v2.x ROMs. I am pretty sure that either Feipoa or myself tried at some point.
Reply 30 of 95, by nzoomed
Anonymous Coward wrote on 2020-08-11, 02:27:
I'll report back anyway.
What versions does you or feipoa have?
I'm going through a bunch of broken links and trying to see if i can get them through archive.org.
For example there is one dated 1994 here:
http://www.weste.net/2005/2-22/10582452137.html
Reply 31 of 95, by Anonymous Coward
1994 is to late for most 486 and 386 systems. In 1994 award started becoming popular.
Reply 32 of 95, by nzoomed
Anonymous Coward wrote on 2020-08-11, 06:42:
Yes quite true.
Anyway, i was able to run the AMISETUP program dated around 1991 and it worked, but it was not able to unlock any features that were not already there.
So I doubt that the AMIBCP would be able to give me anything else of use, unless it includes different modules to install.
Does anyone here have experience with a hex editor in modifying BIOS'?
I think it should be possible to at least change the timing values for the preset "fast" and "slow" options if nothing else.
Reply 33 of 95, by Anonymous Coward
If you want to mod the bios you need to figure out how to recalculate the checksum.
Reply 34 of 95, by nzoomed
Anonymous Coward wrote on 2020-08-11, 09:40:
I was reading a bit about this. From reading other threads, it appears to be possible.
Reply 35 of 95, by Anonymous Coward
I heard the ami checksum calculation is more convoluted than others. I have the source code, but I can’t figure it out.
Reply 36 of 95, by nzoomed
Anonymous Coward wrote on 2020-08-11, 12:03:
Wasnt the checksum there just so the BIOS flash utility could verify it was not going to brick your BIOS when flashing it?
If you were to use an EPROM programmer, would it not just work fine?
Im not sure of all the ins and outs but I thought it was just a protection measure to verify it was not a corrupt image?
Reply 37 of 95, by Anonymous Coward
Yes, it's meant to be a protection measure, but I believe AMI made it more complicated in order to stop peopling from fiddling.
Award on the other hand is relatively easy to figure out.
I tried a number of checksum calculators and I wasn't able to get anywhere.
Reply 38 of 95, by kingcake
Anonymous Coward wrote on 2020-08-11, 00:07:
Wait. They found topcat mr bios?
Reply 39 of 95, by cyclone3d
Which source code? If it is different then the AMIBCP94 code, then I would love to take a look at it.
YMF7x4 Guide
