Reply 35400 of 53092, by Predator99
That ET4000 is very interesting. It has a VGA and a EGA connector. I have many ET3000 with this feature but this is the 1st ET4000 I see. It is much faster compared to a standard 8-bit EGA card.
Should be the fastest video source you can connect to your EGA monitor?
1.59 MiB
12.63 KiB
69.13 KiB
Reply 35401 of 53092, by jheronimus
LewisRaz wrote on 2020-08-11, 20:49:
I sent a low offer for this on ebay and accepted a counter offer of not much more.
Quite a mystery box... Cannot find much/anything about it and this was the only pic provided..
I usually see 286 builds in cases like this. The floppy drive cage position makes this a very comfortable layout for building — particularly if you want to build something with lots of cards.
MR BIOS catalog
Unicore catalog
Reply 35402 of 53092, by jheronimus
mpe wrote on 2020-08-12, 13:00:
#9 Imagine 128. […]
#9 Imagine 128.
This was my dream card back in 1995.
Something about your photos makes them instantly recognisable. I don't know if it's the lightning or the love for cards with green PCB and yellow tantalum capacitors. 😀
MR BIOS catalog
Unicore catalog
Reply 35405 of 53092, by debs3759
#9 Imagine 128.
If the LSI chip is considered the graphics chip, what role does the Cirrus Kogic graphics chip play?
Reply 35407 of 53092, by pentiumspeed
How is the performance of GD5422 also how is the imagine 9 128 main chip GUI accelerator compares to to get the good idea how good it is?
One more thing about imagine 128, I noticed every card has a empty socket next to the main chip, what is this for and can this be installed to help bit more better?
Cheers,
Great Northern aka Canada.
Reply 35408 of 53092, by johnnycontrario
Predator99 wrote on 2020-08-12, 14:03:
Arrived. Very nice deal again..! […]
Predator99 wrote on 2020-08-04, 21:46:
Quite surprised my price proposal was accepted, but I think it was fair. - CT1350B - MACH32 ISA - several SBCs - MFM controller […]
- CT1350B
- MACH32 ISA
- several SBCs
- MFM controller
- 2x ET4000 ISA
- ET4000 VLB
- 386/387
That's a great haul. The 286 SBC has me intrigued. I occasionally think about putting an ISA backplane in a large case and keeping a collection of SBCs to swap around depending on what era I feel like at the moment... because more old computers is something that I need apparently 🤣
Reply 35409 of 53092, by Horun
#9 Imagine 128. […]
#9 Imagine 128.
9rebmun, 9rebmun, 9rebmun. 🤣
Very nice ! Have a slightly smaller version, not as great a performance as you think compared to some Virge cards.
Reply 35410 of 53092, by supercordo
My Dual GPU collection is looking good.
Reply 35411 of 53092, by johnnycontrario
It arrived today. Testing the new Pentium MMX 266 SBC. It came with 2x 32MB RAM SODIMMS, on-board bootable CF card socket,USB controller, ethernet, VGA, etc. Things are testing good so far. I can't wait to try out setmul and see just how granular the speed control can be. The BIOS seems to support some CPU throttling, so there may be some possibility of using CPUSPD on it as well.
Reply 35412 of 53092, by bjwil1991
Deksor wrote on 2020-08-12, 08:18:
Hey can you please help me check something here Identifying PCChips 386 era chipsets ? 😀
I suspect the m326 to have a UMC UM82C491F chipset under the hood (actually I have very good reasons to think it is), but I have no way to verify that.
If you can flash new bios chips, try to run the mrbios ROM designed for UM82C491 and tell me how it goes 😀
I'll definitely do that sometime once I buy a 512Kb EPROM.
Reply 35413 of 53092, by MMaximus
Predator99 wrote on 2020-08-12, 14:05:
That ET4000 is very interesting. It has a VGA and a EGA connector. I have many ET3000 with this feature but this is the 1st ET40 […]
This indeed really interesting! How is the EGA compatibility on that one? I have an ET3000AX card that is surprisingly compatible with EGA games despite it being a dual VGA/EGA card - I wonder if it's the same for this card? (some tricky games I've found so far are "Heroes of the Lance" and "Gods" - if you have access to them)
Hard Disk Sounds
Reply 35414 of 53092, by Camtheman
Microchannel bus clone AdLib because other sound cards are impossible to find for MCA. Even offered $2,000 once and no takers. Oof.
Early 90s: IBM PS/2 Server 95/A, Pentium 66, 16MB RAM, XGA-2, IBM SCSI Corvette, SCSI2SD, 3 Com EtherLink III MCA, Resound 2 AdLib MCA
Late 90s: Micron Millenia MXE, ABIT VH6-II, Coppermine 1ghz, 1024MB, Voodoo 5 5500 PCI, GUS Max 2.1, 128GB SATA PNY SSD
Reply 35415 of 53092, by chrismeyer6
supercordo wrote on 2020-08-13, 02:08:
That is a beautiful find. I really wanted one of those when they came out but being a child that was way out of my price range. How does it perform?
Reply 35416 of 53092, by mpe
Second #9 card this week. I had to call a halt to buying S3 cards for my collection as I own so many of them. However, I could resist buying this one for £8.99 delivered.
I just love how the solder side looks on #9 cards:
Blog|NexGen 586|S4
Reply 35417 of 53092, by debs3759
I love #9 cards for the same reason - no logical reason 😀 Don't have many yet though.
Reply 35418 of 53092, by imi
debs3759 wrote on 2020-08-13, 10:57:
well they're really pretty, reason enough imo :3
Reply 35419 of 53092, by Joseph_Joestar
Bought one of these "sawed off" ESS AudioDrive 1868F cards for next to nothing.
317.2 KiB
I mostly got it because a) it was super cheap b) I was curious about ESFM and its native 16-bit AudioDrive mode for DOS games. And while ESFM did thoroughly impress me, I'm not all that sold on the AudioDrive mode. Granted, I need to run some more tests, but so far, the results have been very mixed.
Some games do sound nicer in that mode, but others become muffled (filtered?) and a few even appear to be downsampled (e.g. WarCraft 2). On the plus side, its SBPro mode is superb. In that mode, the card sounds clean and vibrant and appears to be very compatible as well. Also, it produces no noticeable noise with the jumpers set to the "Line Out" position. As for ESFM, to my ears it sounds very close to genuine OPL3, sometimes even a bit cleaner if that's even possible. Definitively keeping the card.
