Reply 35500 of 60060, by Mephusto
more of the pictures caused they wouldn't all fit. From what I can tell it might be a 486 under the heatsink. The XC87SLC-33 appears to be a maths coprocessor for a Cyrix or Texas Instruments 486 i think from the info i can find online. It said something about a hybrid 386/486 but i got lost at that point
edited for more info instead of making another post
Reply 35501 of 60060, by keropi
^ that hybrid system looks like one I had in the past, it has a 486slc/66mhz from IBM (IIRC) and it's pretty fast
just make sure it has the max of 64kb cache installed as it will give a huge boost to the system
it's a nice weird mobo, lucky!
🎵 🎧 ⏳ ⚡ SoundVision PRO,MK1869 , PCMIDI MPU , OrpheusII , Megacard and 🎶GoldLib soundcard website
Reply 35502 of 60060, by debs3759
Mephusto wrote on 2020-08-18, 16:29:
Thanks Imi! I love those cards you have. I have 1 creative voodoo2 that I always keep an eye out for a match to sli 🤣. And I took pictures of that unkown pc for you all to check out 😀 I think I got decent pics. I saw nothing with AMD or intel on it. Only 1 chip has a heatsink and I am scared to remove it. Anyway, without further ado, the pictures! Oh and the little screen at the bottom still has the plastic cover!!!😁
The chip with the heatsink on will be a 386 variant. You can see the 387 (XC87SLC) right next to it.
Reply 35503 of 60060, by Mephusto
debs3759 wrote on 2020-08-18, 16:58:
The chip with the heatsink on will be a 386. You can see the 387 (XC87SLC) right next to it.
thank you. I was looking that up this morning and thats what I was thinking, glad people with more knowledge than me helped out. I am still learning about the 386 processors and I lucked out and got 2 386 systems!! So much to learn now tho
Reply 35504 of 60060, by devius
It's almost certainly a 486slc or a 386SX because there are only 2x 30 pin SIMMs and those are 8-bit each, which matches the 16-bit buses of those CPUs.
Retro Coisas no YouTube
Reply 35505 of 60060, by imi
Mephusto wrote on 2020-08-18, 16:30:
that's an Alaris Leopard, you are one lucky bastard 😁 that is a magnificent board.
the CPU itself sits under the heatsink yes, and should be a 486slc2 66Mhz, and it includes the elusive co-processor too.
just make sure to get rid of the nasty battery ASAP
Reply 35506 of 60060, by Mephusto
imi wrote on 2020-08-18, 17:07:
that's an Alaris Leopard, you are one lucky bastard :D that is a magnificent board. the CPU itself sits under the heatsink yes, […]
Thank you so much!! I will have to look up that board and see what I can learn about it. And I will research how to remove the battery and put in a CR2032 if i can. Oh and I opened the tall 386 case and I will post the photos soon. It has old paperwork in it, both computers were sold by the same company on 23 july 1990!!
Reply 35507 of 60060, by Mephusto
The psu is similar to the one in the small pc just larger and It has a card with a speaker built onto it. It also has some old paperwork in it.
Reply 35508 of 60060, by imi
woo external battery \o/ that's lucky too
Reply 35509 of 60060, by Mephusto
im not sure which coprocessor goes into that socket or which memory they use, but I thought the external battery was interesting as its a new one for me too....I started pcs around athlon xp days, that was actually my first pc so I am learning all the old stuff now.
Reply 35510 of 60060, by Mephusto
So far, I have 2 - 386 era pcs, I got 2 - pentium ii era pcs, 3 pentium ii 450mhz, some 5.25 and 3.5 floppy drives 2 zip drives and some cd drives
Reply 35513 of 60060, by debs3759
Mephusto wrote on 2020-08-18, 17:56:
Any 387DX or 487DLC will pair with a 386DX
Reply 35514 of 60060, by Mephusto
debs3759 wrote on 2020-08-18, 19:28:
does the 386dx need the 387dx ?
Reply 35515 of 60060, by debs3759
Yes, no 386 have an internal FPU. SX has a 16-bit external bus, DX has 32-bit. Unlike the 486, where DX has an internal FPU
Reply 35517 of 60060, by Mephusto
debs3759 - thank you, i got confused i thought that both 386dx and 486dx had the fpu...whoops 🤣 ill have to look into getting one once I am able to test that they work
imi - I did not know about that site but now i will be able to look around too. Thank you.
and on a side note i forgot to get a picture of the box that came with them. I have 2 AT keyboards....one has a calculator built into it! and a couple PS/2 keyboards and mice. and couple of other items and 2 old LCD monitors
Reply 35518 of 60060, by debs3759
Mephusto wrote on 2020-08-18, 20:37:
It's worth setting up an account at http://www.cpu-world.com/forum/ for when you need to buy an FPU. There is a For Sale forum there, and all manner of CPU/FPU/MCU related chips sell cheaper than places like eBay. Collectors from around the world are active there.
Reply 35519 of 60060, by Mephusto
debs3759 wrote on 2020-08-18, 20:51:
👍 thank you
