Reply 35620 of 58452, by badmojo
Epic as always Artex! I love the 3D blaster story, this is the stuff dreams are made of 🐱‍🏍
Reply 35621 of 58452, by imi
I like quirky input devices... so I had to get this one ^^
The attachment hardware39_53.jpg is no longer available
and this chonky boi :3
it's fascinating how robust joysticks where built back then, well CH ones especially even though they're still mostly just plastic.
but compared to my modern joysticks that are already falling apart after a few years this is just quality.
The attachment hardware39_54.jpg is no longer available
Reply 35622 of 58452, by Artex
Stiletto wrote on 2020-08-23, 03:07:
FWIW furan is reverse engineering Creative CGL drivers and learning about the 3D Blaster VLB in another thread here at VOGONS. I am fairly confident any firmware has been dumped and the included discs imaged and the PCBs scanned/photographed in high resolution, but in case they haven't... not that I think you'd break the seal in that situation, but... FYI. 😉
I do have a second, New-Open-Box card with all the fixings so let me know if there is anything still needed!
Reply 35623 of 58452, by Artex
badmojo wrote on 2020-08-23, 09:27:
Thank you sir! Agreed - I love the backstories on these items and I think that adds to the 'story' of each piece!
Reply 35624 of 58452, by NyLan
Back from vacations in France where I found a small shop and bought these lovely stuff 😀
Sealed Windows 98SE
The attachment IMG_9043.JPG is no longer available
Geforce Fx5500
The attachment IMG_9041.JPG is no longer available
FastTrak S150 TX4
The attachment IMG_9038.JPG is no longer available
PCI soundCard CT4810 ( took from computer in next post )
The attachment IMG_9045.JPG is no longer available
Slot1 P3 500 ( took from computer in next post )
The attachment IMG_9044.JPG is no longer available
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
Reply 35625 of 58452, by PcBytes
Got myself a 3D Blaster Anihilator 2 32MB - Geforce 2 GTS for $1.21.
The attachment 20200823_191106.jpg is no longer available
Had to bend the I/O bracket back and replace the long ago dead HSF.
Reply 35626 of 58452, by NyLan
- Following previous post -
Matsonic MS7112C (P3 Hybrid Motherboard with both Slot1 and Socket 370)
The attachment IMG_9052.JPG is no longer available
Geforce 2 GTS 64MB
The attachment IMG_9048.JPG is no longer available
Elsa erazor III TNT2
The attachment IMG_9050.JPG is no longer available
Aztec ISA Sound Card ( AZT2320 )
The attachment IMG_9060.JPG is no longer available
Labway LWHA151A00 Soundcard (Yamaha YMF719E-S OPL3-SAx) - Took from a warranty-sealed computer, seems it's been plugged back in day and never unplugged until today 😀
The attachment IMG_9068.JPG is no longer available
Personal GitHub
Reply 35627 of 58452, by NautilusComputer
yawetaG wrote on 2020-08-21, 05:35:
NautilusComputer wrote on 2020-08-20, 20:14:
This was given to me after old computers came up in conversation - so it's not exactly 'found' but not 'bought' either.
I love that sliding motherboard tray that comes out with all of the cards still in place! Looks like something from a SF movie... 😁
I'll try and get more pics when I get it more cleaned up. I'm probably going to merge it with the PIII 500 I have - take the better motherboard, the PIII CPU and its Voodoo3 2000, this case, etc.
Reply 35628 of 58452, by devius
Artex wrote on 2020-08-22, 22:14:
A Creative CT6200 (3D Blaster VLB) 2MB (*****SEALED*****) (1995)
Oh wow! I remember drooling over the adverts for this card back in 1995 for a few months before realizing that even if my parents would agree to buy me one (they wouldn't) I wouldn't be able to do anything with it since my PC had no VLB slots.
Reply 35629 of 58452, by HanJammer
imi wrote on 2020-08-20, 19:19:
I didn't even know there was a Tseng ET2000 x3 ... I mean it only makes sense, but still.
Yeah, there was.
ET1000 was Tseng's UltraPAK integrated into single chip,
ET2000 was EGA (with additional 640x480 mode),
ET3000 was VGA with some SVGA modes
Reply 35630 of 58452, by Artex
devius wrote on 2020-08-24, 08:37:
YES! And then as motherboards changed over from VLB to PCI, the expenditure for this card and really sub-optimal performance across the board (fill rate, audio/midi capabilities) really didn't sit too well with those buyers that DID take the plunge on such an expensive item.
Reply 35631 of 58452, by Horun
Just because it was there: bought a working Samsung 914V monitor today for $5 at my local cheap store. Only has VGA input but has all the old IBM/Mac modes built-in as well as the VESA modes, and is a 1280x1024@75Hz model....have not fully tested it yet but as long as it works on a 486 will be happy 😀
Once cleaned and tested might post a picture....
Ok cleaned up and generally in OK condition except a few minor scratches on the screen in one upper left area, is a .29 pixel so not the sharpest. Tested thru a GTX960 using DVI-VGA adapter. Good enough and no dead pixels. Think I got my $4.99 worth considering it will be used on 486 for DOS and Win at no more than 800x600, 🤣
Reply 35632 of 58452, by SilverHawk
Voodoo3 3500tv was delivered this weekend. Put it through the paces and appears to work. Need to figure out a better cooling solution before it gets any long term use. Will post pics later.
Reply 35633 of 58452, by appiah4
@Artex:
Reply 35634 of 58452, by Miphee
Got 4x BEETLE /M-II plus, at least they won't take up too much space!
Also got this 775 board to replace my current board that has no PCI , only supports 8 GB RAM and only has 2 SATA ports, I neglected to check the power connector though so it needs some conversion.
Reply 35635 of 58452, by Dimitris1980
I bought an audio switch from Ebay in order to connect all my midi devices. My audio mixer has 3 channels. One channel is for the sound blaster, one is for the Macintosh computer system sound and the Roland Sound Canvas SC88 (it is connected through the Macman Midi interface at the sound in port of the Mac) and one is for the audio switch. The switch has 4 positions and i have connected the Roland MT32, Roland CM64, Roland Sound Canvas SC55 and Yamaha MU50.
- Macintosh LC475, Powerbook 540c, Macintosh Performa 6116CD, Power Macintosh G3 Minitower, Imac G3, Powermac G4 MDD, Powermac G5, Imac Mid 2007
- Cyrix 120
- Amiga 500, Amiga 1200
- Atari 1040 STF
- Roland MT32, CM64, CM500, SC55, SC88, Yamaha MU50
Reply 35636 of 58452, by canthearu
Woot
The attachment s-l1600 (2).jpg is no longer available
Finally a 2 meg 64-bit VLB accelerator card for my 486 😀
Now just have to wait 2 months for postage!
Reply 35637 of 58452, by pentiumspeed
And you need to short two pins on each connector USB and audio, front panel connectors, for HP motherboard as these boards detects this as disconnected will give you a error on each boot up and press F1 to proceed, yes including the power and LEDs front panel.
I can explain if you wanted to know more.
Cheers,
Great Northern aka Canada.
Reply 35638 of 58452, by NautilusComputer
Looted these out of a box of old leftovers a friend had laying around:
  • Trident TVGA9000A ISA
  • Matrox G450 (I think?) PCI
  • Via-based SATA/PATA IDE controller PCI
  • Some other PATA IDE controller PCI
  • S3 ViRGE DX PCI
  • GeForce 8400GS PCI
  • All-In-Wonder Rage 128 Pro AGP
  • S3 Trio64V2/DX PCI
Reply 35639 of 58452, by MAZter
Have you ever had unusual sales / purchases with disproportionately expensive shipping, when the shipping cost was much higher than the item's value?
Sent a $20 Dell LCD monitor 14" to a buyer in Peru on Saturday, he paid about $86 for shipping.
