Reply 1 of 6, by Robin4
- l33t
On the back is one serial and a parallel poort *aka printer)
The header on the top have a side for a joystick outpot.. (just need finding an Joystick bracket)
Reply 2 of 6, by Grzyb
- l33t
Robin4 wrote on 2020-09-01, 19:38:The header on the top have a side for a joystick outpot.. (just need finding an Joystick bracket)
No, it's the second COM, needs a bracket with 25-pin connector.
There are two UARTs there, and two pairs of 1488+1489 buffers.
Nie rzucim ziemi, skąd nasz root!
Reply 3 of 6, by Robin4
- l33t
A com jumper header is never this wide. Iam certain that a DB25 header is a joystick port is DB25. Serial is DB-9
But it also could be that it is a Second LPT port (thats also is DB25) LPT2
Reply 4 of 6, by imi
- l33t
uh, no there are plenty of old machines with DB25 serial ports.
though most of them still connected with 9pin cables to cards iirc.
Reply 5 of 6, by Grzyb
- l33t
See eg. this - http://www.uncreativelabs.de/th99/i/A-B/50704.htm
There are two 82450 UARTs, two 1488 buffers, two 1489 buffers - so two COM ports.
Reply 6 of 6, by perhenden
Thanks guys!
