First post, by Xenphor
edit: Nevermind, I tried using it and the fan doesn't spin at all when used like that.
I bought a geforce 4 ti 4200 recently and the small fan that is on there now is extremely loud. The cooler is an aftermarket one so that could be contributing to the very high noise levels, but I know even the stock fan is pretty loud. I was thinking of using a low noise adapter with it and plugging it into the motherboard fan header instead. I haven't tried this yet because I'm concerned about potential thermal issues from the fan no longer spinning at a high rpm. Does anyone know if this setup would be safe to use long term? Here is a picture of the card:
Reply 1 of 10, by bloodem
Only you can decide if it’s safe or not, by monitoring the heatsink temps and also the temps on the back of the video card (the region under the GPU).
However, I would recommend replacing the cooler altogether with this one, which works great. There are also other alternatives on eBay or AliExpress.
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 2 of 10, by luckybob
As pictured, it will work perfectly for a long time.
Its not going to make it any quieter, or slower, but won't hurt anything.
if you want silent, buy something like this: https://www.ebay.com/itm/113948834218
Reply 5 of 10, by swaaye
They are effective but do make the card use two slots.
The Thermaltake cooler on it is already considerably beefier than stock so should be ok with reduced fan RPM. It looks like it might even be actual copper instead of copper-colored aluminum.
Reply 6 of 10, by shamino
Slowing down the fan might not be a problem, but try to check the temperature if you do that.
I think a much bigger danger with these cards is outright fan failure or the heatsink coming loose from the GPU. That's what worries me about generic Chinese coolers. *If* the heatsink attaches reliably then that part of it should be fine but I don't trust the fan. Nothing is more unreliable than a generic cheap fan.
I'd prefer a heatsink that allows attaching a standard fan from a reputable manufacturer. Looks like the one luckybob posted would allow that, but it also looks big.
Reply 7 of 10, by Xenphor
Edit: It doesn't appear to work with the low noise adapter.
bloodem wrote on 2020-09-06, 05:15:
I would monitor the temps but I don't believe it has any sort of built-in sensor. That cooler looks like it would have the same problem because I've never used a small fan that wasn't fairly obnoxious sounding, even if it's labeled as quiet. The small Nocuta fans I have need to be used with low noise adapters, because they are pretty loud compared to the standard 120mm. In fact, I'm even using one on a Geforce 4 ti 4800se attached to the stock heatsink with a low noise adapter. It's a bit beefier than the stock fan so I was okay with it.
kolderman wrote on 2020-09-06, 06:28:
Get a better aftermarket cooler, Phils computer lab showed some Zalman-inspired ones from China that would be fine.
https://youtu.be/QodrQadRUOQ
I did get one of those awhile back but it would not install flush to the other geforce 4 I had so I didn't use it.
shamino wrote on 2020-09-06, 15:28:
Yeah this is how my other Geforce 4 is:
So now I may have to do the same thing with this one because it doesn't appear to work with a low noise adapter. The case I'm using is a Coolermaster N200 which has a side intake, but I'm not sure if a side intake fan alone could cool the card enough:
Reply 8 of 10, by pixel_workbench
Was the fan loud from high rpm? Or does it make a racket because the bearings are all worn out? With old used fans, I usually peel back the sticker on the back of the fan and put a few drops of oil in the bearing. That usually solves the noise problem. These fans are not silent, but when working properly it shouldn't make an obnoxious racket.
My Videos | Website
P2 400 unlocked / Asus P3B-F / Voodoo3 3k / MX300 + YMF718
Reply 10 of 10, by adalbert
I just cut the red wire in my Ti4200, soldered a resistor (actually two 1/4W resistors in parallel, so they won't heat up so much as one resistor would) and put a shrinkwrap on it. The resistance was in 10-30ohm range, I don't remember exact value.
It was 5 years ago when such cards were cheap and I didn't care too much about them, but it was working fine. I also solder resistors to CPU fans in all my 486-P3 boards because they don't need a lot of airflow. I wonder why old computers were so loud, probably because no one cared about ergonomics back then.
If you don't have special equipment and want to check the thermals, close the case, run some benchmarks for an hour, open the case (still running the benchmarks) and check if the heatsink is hot. If it burns your finger so much that you can't touch it is too hot, but if it's just warm then it should be OK.
