First post, by Resolution
A cordless drill is not only used to screw-drive but also for drilling hard materials such as wood, plaster, metal, plastic, etc. A cordless drill is really the best cordless tool to have in the house. On the market, there are countless types of cordless drills with different specifications and functions. That's why it became difficult to choose the right one for yourself. Through this article, we will be helping you with this problem. Some advice on how to choose the best model and what to look for in a drill will help you decide on buying a good cordless drill.
To know and decide what the best drill is, first look at what your needs are. When choosing a cordless drill, pay attention to what you really need. Ask yourself the following things:
✸✸✸ Check Here: TOP 10 Best Cordless Drills: Discover the Power Within
How hard is the job?
The power of the drill is the most important factor that determines whether it is suitable for a certain kind of job. The battery of a cordless drill supplies a certain voltage, expressed in volts, which is related to power.
The power of a cordless drill needed can also be decided based on the drill diameter of the holes to be made. You can use lighter cordless drills to drive small screws or drill a hole in the wood, with a maximum diameter of 22 mm.
Go for an average power drill if you need to drill holes between 22.1 mm and 30 mm in size.
Use a heavier power drill to drill bigger than 30 mm on wooden pieces.
If you need an easy to remember the rule: maximum drill diameter – 6 mm = the ideal drilling range for daily use.
How often and for how long do you want to use the machine?
The drill’s energy capacity is expressed in Ampere-hours (Ah). The higher the average of the battery, the longer you can work with one battery. Just like your phone, because it’s cordless! Or you can also compare it to a car; the more gasoline that fits in your tank, the longer it can drive.
If you would like to use the drill daily and for a long time, we recommend taking one with a battery of 3 Ah or more so that you will not end up with an empty battery with just q quick use.
If you only use it occasionally and short-term, go for 1 or 2 Ah, that’s sufficient.
Do you need one or more gears?
Typically, cordless drills have two gears. Gear one is a lower speed and higher torque, which is most suitable for screw-driving. Gear two is with a higher speed and lower torque, which is suitable for drilling.
There is usually a slider to change for gear 1 to gear 2 and vice versa. However, there is also a drill that has only one gear. These are only suitable for screwing or drilling on wooden surfaces.
There are also drills that have more than two gears, which give you more control over the speed while drilling or screwing.
Do you need to drill on hard stone and concrete?
Many drills on the market right now come with an extra function, such as a hammer. It is suitable even for drilling in concrete or hard stones. The drill can generate a hammering motion, which helps while working with hard materials.
Other things that you may find important.
Other than the things that were mentioned, things like the number of batteries could also be important for you. If you plan to work with the drill for a long time, considering a cordless drill with two batteries is highly recommended.
The battery technology could also be important. Because what is the best cordless drill ? It is the one that you can work with, without having to plug in or deal with wires while working. That’s why a battery is used. A vast majority of electrical equipment, including drills, have a Li-ion battery. This technology has many advantages over NiCd and NiMH batteries. But it is more expensive than the latter two.
The maximum torque could also be important. The higher the maximum torque, the more powerful the machine, and the easier it is to screw.
The bits and drills.
Always use the correct bits when inserting and removing a screw out of the surface you are working with. Using the wrong but could cause the cordless drill to spin over the screw head, which leads to an unusable screw quickly, and your bit will wear out very quickly. The type of bit and the size of the bit are both very important.
There are also special drills for wood, metal, stone, or concrete. If you use a suitable drill for each job, the drill will be more durable, and the quality of your work is higher. If you don't know yet what you want, or would be working with all the materials, go for a complete bit and drill set! It will make your life easier.
From knowing all your needs to making a purchasing decision, there is still a gap. That’s why we are here to help! In the next part, we will be bringing you the best cordless drill reviews. We hope you will be able to select a suitable one for yourself!
1. Bosch PSB 1800 LI-2 System box.
This is a nice and complete set that you can use for many situations, from assembling furniture to making your own garden shed. It includes a hammer function to drill into hard materials like brick or concrete.
It comes with 241 accessories and two batteries. Imagine how many projects you can do with this!
This is one of the top-rated cordless drills right now, and the price is not as high as you think! It’s really the best value cordless drill!
2. DeWalt DCD777S2T-QW.
This is a compact cordless drill that can effortlessly drill 30 mm holes in your wood. Heavy screwing should not be a problem too. Its maximum torque is 65 Newton meters. Thanks to it being very lightweight (1.5 kg), you will not be suffering from the pain the next day.
The drill is able to adapt to your job, adjusting its speed automatically to have optimal control.
It also comes with two 18V batteries.
3. Bosch GBH 18V-26 F
With this model from Bosch, you can literally drill everything. This professional cordless drill is really one of the best cordless power drills.
The compact drill works on an 18V battery. It also has a hammer function that allows working with hard materials.
It comes with extra functions such as electronic engine protection, LED light, overload clutch, variable speed, Vario lock, vibration control, kickback control.
Two 6.0 Ah Li-ion batteries are included and allow you to work for hours long.
✪✪✪ Find More Information: https://thekinglive.com/dewalt-dcd996-cordless-drill.html
Those are three recommendations that we have for you if you are still looking for a highly rated cordless drill model. We hope that you have enjoyed the read!
Don't forget to tune in often for new articles on cordless drills as well as other household appliances.
