First post, by sebulba
The subject says it all ; is that a problem that can exist ?
I have a toshiba T2130CT, that is in supposedly perfeftly working condition
I can hook a serial mouse on the com1.
But it does not work with a modem ( what I type doesn't appear, modem not detected by windows, etc )
Is that a problem that can exist, like, do mie use less pins than a modem, and so could one of the pins be desoldered and make it a partially working com port?
Or to the contrary, if a mouse works a modem should 100% work, if so what could I investigate ?
As I have multiple toshiba laptops of the same era, the modem & cable absolutley work ( USR SPortster ).
thanks !
Reply 1 of 3, by Grzyb
I would begin with veryfying the COM port in Checkit 3.0 with loopback plug.
Kiełbasa smakuje najlepiej, gdy przysmażysz ją laserem!
Reply 2 of 3, by matze79
Does it work to send at commands with terminal Programm ?
Reply 3 of 3, by matze79
sebulba wrote on 2020-09-08, 07:55:
thanks !
Mouse only requires 4 wires of the rs232 port, rx,tx,dtr,Gnd
So mouse can also work with partial defective port
