Thanks for the feedback! I really appreciate it! 😄
Well, it's a start, at least. So we have the boot code for DOS 1.x, at least.
So a pro in ASM or machine language programming might be able to adapt it for loading DOS 2.x/3.x system files.
Or maybe it's even possible to convince the SYS command of DOS 2.x to run on DOS 1.25 ?
I got this method working on DOS 7 in conjunction with DOS 6.22 SYS.COM, at least.
It involved changing DOS version number and a temporary drive letter (another partition, floppy drive, RAM disk).
Edit: Once we are this far, maybe an emulated Sirius/Victor could be used to transfer the data over to the real one via serial.
Or maybe someone is able to write a host program (Windows/Linux/Mac etc) which provides data to the real PC.
The makers of the XT-IDE Universal BIOS, for example, made such an untility: XUB can boot via serial port, too.
If I had a Sirius/Victor machine, I would gladly send you a physical copy of a boot disk.
Unfortunately, I have no access to such a machine. If I see one, though, I'll ask its seller/owner for a copy.
That being said, maybe PCem/86Box will someday add Victor emulation.
At this point, the community might be able to help or source physical copies of these boot disks.
Until then, the Sirius 1/Vic 900 remains an oddity very little people ever heard of.
Which is a shame, since that machine is a pioneer in its own reign, similar to the IMSAI 8080 used to be in the Z80s days.
