First post, by blk90sho
I'm trying to install tornado on my computer w/windows XP. It says I need to change my buffers from 0 to 20 in the config.sys file. I've tried to do it in the command prompt for Dos but windows pops in with a caution then says "windows cannot open this program". I hate windows and how do I get it to stop interfering w/Dos so I can change my settings?
Reply 1 of 4, by blk90sho
Well I found the edit config screen(C:>edit config.sys) and it says:
files=40
buffers=30
But when I go to the install screen it says
Needed to run game
files/buffers 30/20
You have
files/buffers 40/0
WTF????
Reply 2 of 4, by Dr. Riptide
C:\config.sys is ignored by default; it's actually looking at "C:\windows\system32\config.nt" instead. Most likely, this file doesn't even have a BUFFERS setting, so you'll have to add one.
Intel Q6600 (2.4 GHz) | 4GB RAM | GeForce 8800 GT | Windows 7 64-bit
Reply 3 of 4, by blk90sho
Well, I went into that screen and added the line "buffers=30" directly under the files=40 line and it still says I have no files under the install screen. What am I doing wrong?
