First post, by kirikl
- Member
Hello. I just want to know if it's possible to copy command.com to c: (ram drive) and THEN redirect it so laptop is not using FDD every time to execute commands. Executing command.com form c: after is ok, but it takes so much memory 😒
GA-5AX/k6-3+ 600mhz
XT Turbo 10mhz
HP TC4200 / NC6400
Sony Vaio PCG-SRX99 / PCG-505TR / C1 Picturebook
Compaq LTE Elite 4/75CXL / LTE 5000
Toshiba T1100+ / T3100e/40 / T3200SXC
Tandy 1400 LT / 1000HX
PB G4 1.33 / G3 300
iBook Cl 300
