Reply 2860 of 5062, by Aublak
I finally found a V3 3500. Here's hoping she still works.
Reply 2861 of 5062, by aha2940
Aublak wrote on 2020-09-11, 03:24:
Cool find, just put a heatsink on it before trying it, those things can get pretty hot.
Reply 2862 of 5062, by darry
aha2940 wrote on 2020-09-11, 05:20:
I second that and recommend that you have at least a fan blowing across the surface of that heatsink and also on the EZ1580CM regulator before putting it into long-term use .
Reply 2863 of 5062, by appiah4
Good luck finding the breakout cable..
Reply 2865 of 5062, by Aublak
austinham wrote on 2020-09-11, 19:27:
There is two on ebay right now.
One is being sold for parts the the is used and a buy in now.
I simply bought a DVI-to-VGA adapter
https://www.ebay.com/itm/DVI-I-Digital-Dual-L … 872.m2749.l2649
Cheap enough to try out
Reply 2866 of 5062, by Thermalwrong
appiah4 wrote on 2020-09-11, 09:24:
Can't it just use a DVI to VGA adapter? I recall that being safe, but I've never had a V3500 to test so idk 😁
Reply 2867 of 5062, by darry
Aublak wrote on 2020-09-11, 20:22:
I simply bought a DVI-to-VGA adapter […]
I do not think that will work . See Voodoo3 3500TV, connect to monitor?
Reply 2868 of 5062, by Aublak
darry wrote on 2020-09-11, 21:25:
I think I may be good. The adapter I bought was dual link. It spits out both analog and digital.
That 3DFX breakout cable is too expensive and I'd rather not have that "octopus" sticking out the back. Yuck.
Reply 2869 of 5062, by darry
Aublak wrote on 2020-09-11, 22:49:
I agree with your sentiment about the purple octopus, but I am afraid even a dual-link DVI adaper will not fit . You need a P&D connector, AFAIK .
See http://www.cablesonline.com/dvianddfpcab.html
EDIT: Pretty sure you need something like this. https://www.amazon.com/Monoprice-Male-HD-15-F … r/dp/B01EIJWQ5A
Reply 2870 of 5062, by Aublak
darry wrote on 2020-09-11, 22:53:
I agree with your sentiment about the purple octopus, but I am afraid even a dual-link DVI adaper will not fit . You need a P&D […]
Something like this? Its DVI-A and its right here in Ohio. So It'll probably arrive quick.
https://www.ebay.com/itm/DVI-A-12-5-PIN-MALE- … 872.m2749.l2649
Edit: Okay, I see its not just analog. I wasn't sure what the P&D meant. It has a different shaped connector.
Reply 2871 of 5062, by austinham
Aublak wrote on 2020-09-11, 23:28:
Something like this? Its DVI-A and its right here in Ohio. So It'll probably arrive quick. […]
the voodoo 3500 does not have dvi. It looks like dvi but its not.
Others have modded such dvi to VGA dongle to make it work however. 3DFX also sold a dongle that did not need the blue brake out mess.
Reply 2872 of 5062, by Aublak
austinham wrote on 2020-09-12, 01:41:
Yeah, I see now.
Interestingly I may have a HDMI option as well.
https://www.ebay.com/itm/Gold-Plated-M1-D-Mal … iQAAOxyuPtQ-EZ2
Reply 2873 of 5062, by darry
Aublak wrote on 2020-09-12, 02:07:
Yeah, I see now. […]
Yeah, I see now.
This looks like a passive adapter, so the HDMI out will not work on a Voodoo 3 3500 because it only outputs analog RGB (VGA), AFAIK . Apparently, there exists a MAC version with actual DVI output that can be flash to work in a PC, or so I've read .
Reply 2874 of 5062, by austinham
Yeah, I see now.
No, it will not even remotely work. The voodoo 3500 and hdmi are years apart. On top of that the voodoo3500 dose not have dvi like I and others have said. Is analog not digital. You can mod some DVI to VGA adapters and that's about it.
Reply 2875 of 5062, by Aublak
Got the adapter for the 3500, but it doesn't work as I hoped.
There's some artifacting and color issues. It may be due to me replacing one of the lost SMD capacitors with the wrong one. I just stole some random capacitor from another broken Voodoo3 and slapped it on. I dunno how I could find the correct capacitor. And even if I did, would that even fix the artifacting?
I dunno enough about figuring this stuff out unfortunately. Damn, I really wanted this thing to work.
Reply 2876 of 5062, by bjwil1991
Video RAM issues cause that. I believe capacitors don't do that unless the voltage, capacitance, tolerance, and temperature + lifespan aren't too low.
Reply 2877 of 5062, by Miphee
Press on the BGA chip carefully while it's on to see if it's a soldering issue. You could do the same with the RAM chips as well.
Reply 2878 of 5062, by Aublak
Miphee wrote on 2020-09-16, 05:02:
That main chip gets so hot, its like asking to touch a hot stove.
Reply 2879 of 5062, by imi
umm... you're only testing WITH a heatsink? right?
just put a fan blowing air on it should be cool enough to touch.
